Volks AutosMonster Motorsport
Results 1 to 14 of 14
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,970
    Hladex Oil and Filter change prep...
    Hi All,
    In order to hopefully cure a problem with the rear wheels dragging/locking on full lock I'm planning on giving the haldex oil and filter a change this weekend. After reading some guides online I'm expecting to only need the following:
    - 1 tube of haldex fluid
    - 1 pressure pump gun
    - 1 filter
    - 1 filter removal spanner
    - 1 5mm allen key
    Is there anything else anyone recommends based on experience? I'm planning on getting it up on some axle stands to do the job, will your average axle stands get the car high enough to manouvre under the car with the gun?
    Input appreciated.
    Cheers,
    Dave.
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,021
    If you are doing this on the 'drive' on stands etc then there generally isn't enough room to hold the oil/caulking gun vertical.. one tip is to cut the nozzle of the oil in half and use a bit of rubber hose to join the nozzle back together to allow you to hold the oil horizontal but direct the nozzle up to the filler hole... and be quick with the filler plug when removing the nozzle after filling else all the oil will be on your face
    Get the haldex warm too... go for a quick drive first...
    <tuffty/>
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,970
    Thanks mate, I haven't got any hose lying about but I suppose I could pick some up from somewhere, just need to get the internal diamter correct I suppose...
    I'm tempted to buy two tubes of haldex fluid just in case I cock it up the first time!
    > S3 225 (03) - OEM+
    View: My S3 diary
    Oct 2010
    Hampshire
    286
    I always fill through the breather/ level check hole with the drain plug in place. Tube with no gun fits nicely down the side of the exhaust and then use a long socket extension bar or similar to push the oil through as it doesn't take much force. Any excess will then dribble back out. Saves the hassle of filling through the drain hole.
    Check the temperature using VCDS, AWD module block 002 i think. Oil should be 20-40 degrees.
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,970
    Thanks for the advice pj123. I'll have a nosey where the check hole is and see which method looks easiest.
    > S3 225 (03) - OEM+
    View: My S3 diary
    Schlaag's Avatar
    Bwah
    Jul 2007
    Kent
    286
    let me know how you get on mate, ill be doing this later today!
    Feb 2006
    Lincolnshire
    691
    I used to do these frequently on my old A3, and I had the brain wave one day of just bending the nozzle through 90 degrees so that I could get the gun under when it was on axle stands.
    It sounds nonsense, but it works. No tubing required. The oil is quite thin, and easily goes through the crease in the nozzle.
    Audi S3 - 2002MY - Denim Blue
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,970
    Will do, I'm going to give it a go on Saturday morning so if you learn anything handy later today please share it
    > S3 225 (03) - OEM+
    View: My S3 diary
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,970
    Whilst doing general research on't t'internet I found this thread: The Audi TT Forum :: View topic - Grinding Noise when turning?
    So I'm now shatting myself that if the oil change doesn't solve the problem, the whole thing could get a lot more complicated and expensive....another deep dive into the money pit!
    > S3 225 (03) - OEM+
    View: My S3 diary
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,970
    Also, how do I edit the thread title? Just noticed that I've spelt Haldex wrong! [type spaz].
    > S3 225 (03) - OEM+
    View: My S3 diary
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,637
    Mines the groaning noise on full lock at low speed which makes me hope an oil change will sort it.
    Going to be spending a lot on this car in the next month at least it'll be mint!
    Handling mods++. GTX30 soon-ish. Hiding parts from the mrs since 2011. Build thread
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Does any one replace the washer when filling up from the bottom?
    On my ETKA there are two sealing washers listed: 02D 525 655 or 02D 525 655 B
    Ta, Liam
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,970
    Quote Originally Posted by Sam_ View Post
    Try pulling fuse 31 and replicating the motion that cauases it to groan, if it stops groaning then you've got an electrical issue somewhere. If it carries on groaning then you've got a mechanical issue i.e. either the haldex clutch plates or the diff. I was concerned mine was mechanical until I pulled fuse 31 and the noise went away...it has turned out to be the earth strap:
    > S3 225 (03) - OEM+
    View: My S3 diary
    Schlaag's Avatar
    Bwah
    Jul 2007
    Kent
    286
    Also a cartridge gun isn't required at all, the oil is very thin. Just use the handle of the filter removal tool to push the oil out in to the drain hole.
  1. Oil Capacity - Oil & Filter Change
    By Silky-S3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th February 2012, 17:12
  2. engine oil change should i get a genuine oil filter
    By dusty in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th July 2011, 15:50
  3. oil leak and oil/filter change
    By scott13 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st February 2011, 22:09
  4. OIL and filter change
    By RyanJonS4 in forum Awesome GTI
    Last Post: 18th June 2009, 09:01
  5. oil and filter change
    By Banwell in forum Tuning
    Last Post: 17th March 2004, 10:21
