EM TuningMonster Motorsport
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    9,640
    Removal of the Boot Lock Strip - HOW??
    Hey guys,
    Ive got some corrosion on the boot locking strip on my facelift S3, I want to have a go at rubbing it down and spraying it so it looks half decent rather than having the paint flaking off, however Im not too sure how it comes off, any ideas how you can remove this, is it pretty straightforward and finally any tips on prep and spray?
    Thanks in advance
    Nilz
    Jan 2009
    West London
    269
    There are two nuts that hold it in place. You need to remove the trim on the back of the boot, disconnect the light/switch connections and you can access the nuts from the inside to remove them and take it off.
    Nilz's Avatar
    Apr 2006
    9,640
    Does the trim come off pretty easily, as in is it screwed in or just clipped on?
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,169
    Im sure animal tried removing his and gave up as it was on tighter than a nuns chuff.
    Nilz's Avatar
    Apr 2006
    9,640
    Great!!!
    Ill give it a blast over the next few days and see how I get on, if its easy enough, I will do it, otherwise, may just spray it whilst its on the car.
    Jun 2007
    38
    If you do end up painting it on the car, make sure you sheet up the whole of the back end. Nothing worse than being able to see something that is freshly painted and then has a news paper sized bit of good paint then everything else is just overspray.
    2000 A3 TDI 90.
  1. URGENT boot lock removal??
    By boya in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th August 2011, 11:24
  2. De-chromed boot strip
    By mattyboyc in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th February 2010, 19:01
  3. S3 Lock Strip Warning! (and mines for sale!)
    By fran-s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th May 2009, 11:20
  4. door trim and lock strip corrosion fix
    By jcb in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th April 2008, 12:17
