JMB RetrofitsEM Tuning
    Tricki's Avatar
    Getting into it
    Nov 2011
    Bergen, Norway
    114
    Help Needed! Vibration at full throttle
    My car has been running fine up until recently, when I have started to feel a vibration in the acceleration when giving it full throttle at about 3000 rpm and upwards. Mate of mine first had a theory that I needed new plugs, but I have swapped them without any result. have also been thinking it can be a bad tank of fuel because it coincides with filling a full tank a station I'm not familiar with, and if they don't sell that much 98 it might be bad.
    However, the latest theory is that the engine gets too little fuel, I don't know how, but apparently turbo engines should have black dry residue on the plugs, but mine look like this (not this bad actually, but along those lines), indicating it runs lean?
    Anyone had similar experience with vibrations? It' really bugs me this, can't drive the car the way I want....
    S3 2002 AMK | O.CT stage 1 | K&N | Forge 008 | H&R Spacers R20/F10 | H&R Springs | N249 Deleted
    Forge Tie Arms | Forge Short Shift | Forge TIP | 18" TSW Nurburgring Gunmetal w/GY ASY2 | Mintex Discs (F)
    Next : Bilstein
    B8's + ARB's | Haldex Competition Controller
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,087
    Possibly another case of faulty coil packs?
    Are you getting any engine management lights?
    Have you had your car in for coil pack recall??
    If not get in touch with Audi and they maybe able to replace them FOC and see if that helps, ideally you want to get your car scanned and see if it brings up any fault codes at all.
    Tricki's Avatar
    Getting into it
    Nov 2011
    Bergen, Norway
    114
    Quote Originally Posted by Nilz View Post
    No management lights and I don't know if the coil packs has been changed, but I somehow doubt it... I will try to get the codes read and see if anything comes up. Cheers!
    Next : Bilstein
  1. Help Needed - Cant Full Throttle !!
    By mo_s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th February 2012, 19:00
  2. Strange vibration under full throttle acceleration. Any ideas?
    By Prawn in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th July 2011, 15:21
  3. 8P S3 Full throttle problem??!!
    By gnic13 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th January 2011, 21:01
  4. Faster on part throttle than full throttle?
    By ianysm in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th May 2010, 21:49
  5. vibration when full throttle
    By marv in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th April 2010, 18:04
