EM TuningMonster Motorsport
    2000 a4 1.8tqs-yellow
    May 2008
    perth
    1,197
    Some fault codes
    VCDS-Lite Version: Release 1.0
    Tuesday, 01 May 2012, 12:00:38.
    Chassis Type: 8L - Audi A3/S3
    Scan: 01,02,03,08,15,16,17,22,35,37,45,55,56,57,75,76
    Address 01: Engine Labels: Redir Fail!
    Controller: 8N0 906 018
    Component: 1.8L R4 5VT 0003
    Coding: 05610
    Shop #: WSC 79671
    No fault code found.
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: Redir Fail!
    Controller: 8N0 907 379 A
    Component: ABS/EDS 20 IE CAN V001
    Coding: 13504
    Shop #: WSC 00455
    Tuesday, 01 May 2012, 12:01:33.
    Control Module Part Number: 02D 900 554 B
    Component and/or Version: HALDEX LSC ECC 0006
    Software Coding:
    Work Shop Code:
    1 Fault Found:
    01155 - Clutch
    04-10 - Mechanical Malfunction - Intermittent
    I know the haldex one could be one of a few things but what are the others on about?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    What others? no fault found for the other two modules?
    <tuffty/>
    RIP S3dave
    May 2004
    nr Glos
    7,175
    Quote Originally Posted by ian52 View Post
    Coding: 05610
    Shop #: WSC 79671
    Coding: 13504
    Shop #: WSC 00455
    Software Coding:
    Work Shop Code:
    1 Fault Found:
    01155 - Clutch
    Is there more to paste in which is'nt showing above?
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    May 2008
    perth
    1,197
    Just the redir fail bit. What's that?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    Redir Fail is a VCDS thing for label look ups...
    Control Module Maps - Ross-Tech Wiki
    <tuffty/>
  1. Fault codes can anybody help ?
    By macpdm in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st October 2011, 19:53
  2. fault codes
    By lnewland in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th October 2011, 12:31
  3. fault codes
    By mad max in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th June 2010, 21:49
  4. Need help with Fault codes please
    By xlr8 in forum VCDS (formerly VAG-COM) forum
    Last Post: 10th August 2007, 22:57
  5. misfiring fault, tech help needed - have vagcom fault codes
    By shufti in forum General Technical / How To
    Last Post: 16th June 2006, 22:14
