AH FabricationsBadger5
Results 1 to 7 of 7
    Mar 2011
    buy st edmunds
    65
    sheared stud in exhaust manifold to turbo
    damn cars starting to be a pain now im discovering all the previous bodges
    exhaust had a slight blow slowly getting worse i discovered a nut wasnt done up looking from above engine in middle at back below red pipe off turbo can see 3 nuts the center one at top wasnt done up. tried and was tight so tried gently undoing it and it sheared off straight away!!
    any tips suggestions please as now its blowing badly
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,284
    Oh dear that's not fun! I had the same but with one of the downpipe bolts. Tried to use an "easy out" which also sheared off inside and then ended up having to drill it all out. Luckily for me I was already taking the turbo out.
    If it's sheared flush with the turbo then I think you're going to have to take the turbo off to sort it.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Mar 2011
    buy st edmunds
    65
    looks like a fair bit of thread left its sheared just below the maifold level. how many bolts hold the turbo up is it just the three seen from above?
    if so if i undo the other two would it be possible to drop the turbo slightly enough to get some grips on the thread and try wind it out?
    Westy's Avatar
    Dec 2008
    17,284
    Quote Originally Posted by kaos View Post
    Yeah just the 3 bolts. If you can get it out with grips then you'll save yourself a load of work. Good luck.
    S3 Build Thread
    Mar 2011
    buy st edmunds
    65
    well i went to do this and my 17mm socket wouldnt go on the other two nuts. its seems the maifold is in the way. guessing i need one of those alloy wheel thin wall sockets??
    :s
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,389
    don't use a deep socket on them, use a normal 17'' socket and a wobble bar
    Mar 2011
    buy st edmunds
    65
    I tried 4 different sockets two of which are my best snap on short 6points and they just wouldn't go on the manifold is so close to the nuts ?? :s
  1. Rebuilt K03s turbo / downpipe / big bore exhaust manifold / remapped ecu AGU
    By beachbuggy in forum For Sale/Wanted - Audi Parts
    Last Post: 16th February 2012, 22:42
  2. Turbo To Exhaust Manifold Gasket & Manifold Gasket :(
    By Dazboss in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th February 2012, 14:42
  3. Exhaust stud drilled out but went alittle to deep ?
    By andysAko4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th October 2010, 11:39
  4. Gaskets for Turbo and Exhaust Manifold needed please..
    By mo_s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th September 2010, 13:54
  5. N90767801 K03 Turbo/Downpipe Stud
    By Welly in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd November 2009, 13:39
