AH FabricationsBadger5
    MrTackalakalaka's Avatar
    Jan 2012
    Truro, Cornwall
    426
    Wheels Bolts/Locking Nuts
    Hi everyone
    Need to buy some new locking nuts for my alloys!
    First of all......my rear wheels have 25mm spacers on them with 50mm (measured the shaft) bolts and my fronts have 15mm spacers with shorter bolts.
    If i get locking nuts that are long enough to fit my rear wheels with spacers (50mm). will they be ok on the front? they won't hit anything and half the bolt will end up sticking out?
    Also looked at my bolts that came out of my rear wheel......it looks like theres about 10mm of thread that actually reaches the hub which i thought was a bit scary haha. Is this ok? Obviously i tighten them up with a torque wrench and never had a problem with them coming loose *touches wood*
    Cheers!
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    Well standard wheel bolt length is 27mm. So just add on the extra spacer.
    Example for your front you'd need 27+15...42mm length bolts.
    Rears would be 27+25...52mm!!
    MODS - Custom Code phase 1, 007p DV, various powerflex bushes, EBC grooved and drilled - red stuff pads, N249 deletion. Badger5 V2 80mm TIP. Scorpion backbox + custom centre section, LCR front splitter, Jetex Fr-08001, R32 rear ARB, Forged IE rifle drilled rods, 20mm rear & 15mm front spacers.
    TO DO - Coilovers, adjustable tie arms, DP/mani/decat, FMIC and new remap
    Jan 2012
    Truro, Cornwall
    426
    Quote Originally Posted by S3featesV9 View Post
    Thanks mate!! Thats awesome help!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,591
    Nope... you will need two different sizes... cut the ones for the front down and just make sure they are only ever used for the fronts...
    If the bolt is too long it will damage the ABS sensor ring and/or lock the hub against the carrier doing all sorts of untold damage...
    Bolts should be long enough that they protrude a couple of threads past what they screw into... typically you make them the same length as the std bolt (of the thread or the bit that sticks out the wheel when off the car) plus your size of spacer... so... while a wheel is off, poke a std bolt through and measure how much sticks out... add the size of the spacer and bingo...
    <tuffty/>
    Jan 2012
    Truro, Cornwall
    426
    <tuffty/>
    Thanks Tuffty!!
    Jan 2012
    Truro, Cornwall
    426
    I forgot to mention I already have some locking nuts on the front......but none on the back.
    Ive just ordered a set for the back but will cut the other two down for the front!
    Locking Wheel Bolts – McGard 27208SU M14x1.5 17 mm From Performance Alloys.com® – The Alloy Wheel Experts™
  1. locking wheel bolts for wheels with spacers
    By solaris in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 23rd April 2011, 20:54
  2. Locking wheels bolts??
    By OllieH in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st February 2010, 20:37
  3. Longer locking wheels nuts
    By stapo69 in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th May 2007, 19:02
