Monster MotorsportBadger5
Results 1 to 10 of 10
    Jul 2011
    teesside
    16
    knocking noise, left front wheel
    How do, my s3 has developed a knocking noise from the front left wheel, not the top mounts had them done recently, i suspect the drop links as it only occurs when turning right when the weight of the car shifts that way, anyone else had this issue, just wondering if its the right thing to be looking at!
    addy
    Jun 2007
    38
    Usually the easiest way to find out is jack the car up then pry along all the bushes. If something like that has gone or a ball joint you will be able to see the excess movement.
    2000 A3 TDI 90.
    Jul 2011
    teesside
    16
    Had it up earlier and the only thing that moved and rattled was the driveshaft, could be the cv joints?
    Sep 2011
    tiverton
    337
    Add egesford on Facebook
    i have the same problem, am guessing driveshaft
    Jun 2007
    38
    Guessing you can't see a split boot or anything?
    2000 A3 TDI 90.
    Jul 2011
    teesside
    16
    I didn't have time for a full look, but Im guessing as its the only part i could move around by hand , and it did slightly replicate the noise, so going to block change inner and outer joints and reboot and grease them, driveshafts work out at about a ton each don't they?
    Apr 2012
    Tunbridge Wells
    105
    I had a similar issue on my S3, turned out to be the bracket that the ARB bushing rests on had snapped clean off. The play in the ARB was huge, causing a nasty knocking sound. Easily rectified though, just fitted a new bracket and bushing, and all sorted.
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,897
    It's more a clicking noise for cv's,droplink is more of a clunking iirc.
    Jul 2011
    teesside
    16
    The noise only comes when under acceleration, as soon as i lift its gone, that's what's made me suspect the cvs on the driveshaft, that and the play in it i felt too
    Oct 2006
    North Herts
    168
    Hi Addyboult,
    I seem to have the same problem as you, did you ever get to resolve this?
    Jit
    Audi S3
  1. Knocking noise front!
    By steviet in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th May 2011, 17:44
  2. knocking and grinding noise on left hand bends
    By wickyianr1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th October 2010, 21:13
  3. knocking noise turning left job done
    Last Post: 12th October 2010, 20:04
  4. front knocking noise
    Last Post: 22nd June 2010, 10:38
  5. Knocking noise from front.
    By low610 in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd May 2008, 09:01
