Monster MotorsportBadger5
    Crazypete00's Avatar
    Oct 2007
    266
    Xenon light adjusters
    Hey, I have the common issue that the white clip in my light has broken, not too fussed because I can sort that. However on the opposite side light the clip is fine but the motor that's meant to clip into it doesn't reach the clip. I tried pulling the white adjuster out but it doesn't extend, any ideas?
    I also need a new motor any idea how much they are?
    Aug 2011
    Ruislip (Middlesex) & Longbridge (Birmingham)
    43
    i have got 2 levelling motors.
    pm me and can talk about price and sending them out if you want them??
    thanks
    Rob
    Jan 2011
    84
    HI mate ,
    You can actuate the levelling motor with a 9volt battery . If you disconnect the plug and remove the cover 2 or 3 tabs on the back from memory , you'll see three metal contacts . Taking a 9v battery with a live and earth lead to each of the outer prongs , easier with crocodile clips attached . Hold them on for a few seconds and you should see the ball end of the motor move in or out . To change direction of movement simply reverse polarity . should get the motor to the required position . Ideally you need vag com to to set up the correct position once fully installed . Hopes this helps .
    Ant
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,868
    Oct 2007
    266
    Thanks both for the reply,
    @ voorhees - already thinking of putting my name down for those, I have a clip that is very similar that I need to try first.
    @ ant - will try the 9v battery on it, I also have vag com so once I repair the other side I will set it up with vcds.
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Hi
    The adjusters can be a pain to get back on to the clip some times.
    Try removing the back off the head lamp and gently pulling the reflector/clip towards the adjsuter arm as you rotate and twist the adjuster to get it to slide in to the clip from one end.
    Liam
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
  1. Head light adjusters
    By ScottD3 in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th March 2012, 12:15
  2. Xenon Adjusters - A3 8P 3dr
    By MarkTweedley in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th July 2011, 17:47
  3. can i just disconnect the stupid xenon adjusters?
    By jediknight in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th May 2011, 12:50
  4. Disconnecting automatic xenon head light adjusters....
    By Dani_B19 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th May 2010, 14:29
  5. S3 Xenon light rating
    By Nilz in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th April 2008, 11:22
