Chris NottVolks Autos
Results 1 to 9 of 9
    Scullies's Avatar
    Feb 2012
    Dubai
    1,240
    S3 hesitant at WOT
    Before I had a remap done my S3 would hold back at WOT, if you pressed the pedal almost to WOT about 1cm short, it would boost nicely and run strong.
    Now that I have had a remap done, its still the same but obviously feels worse since there is more boost. Same story though, at WOT you dont get that blured vision, fast and furious style but 1cm short of WOT and its all a blur
    Anyone know what is causing this? I feel the need to shorten the accelerator cable a bit but its fly by wire !!
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Coil packs breaking down, or tired fuel pump?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    Any fault codes? could be torque monitoring intervening... what map is in it?
    <tuffty/>
    s3mad_dude's Avatar
    Noggies ruuuule!
    Jan 2006
    Hampshire
    462
    What does WOT mean?
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Quote Originally Posted by s3mad_dude View Post
    What does WOT mean?
    what?....
    Wide open throttle.....
    Scullies's Avatar
    Feb 2012
    Dubai
    1,240
    I have changed all 4 coil packs for the Tfsi coil packs. Left the plug gap the same tho. Car did the same thing with the old coil packs with the remap.
    I have these 2 faults, the EVAP one is new, just before remap. Coolant one has been there for about a month. Plan to fix this soon. Been on vacation.
    16825 - EVAP Emission Control Sys: Incorrect Flow
    P0441 - 35-00 - -
    16502 - Engine Coolant Temp. Sensor (G62): Signal too High
    P0118 - 35-00 - -
    Also have the following with the AWD
    65535 - Internal Control Module Memory Error
    00-00 - -
    I'm not sure what you mean by , "what map is it in"
    Do you mean what stage?
    Its a custom map by a tuner here in Dubai.
    I also logged the mass air flow this morning, using meas block 002, the highest I got on a remap was 150gs, I thought the gs would be over 200
    Engine Speed Engine Load Injection Intake Air Mass
    Timing
    /min % ms g/s
    1960 12.8 1.7 5.08
    1960 62.4 6.8 26.61
    2120 82.7 8.5 36.06
    2400 96.2 11.22 47.72
    2800 119.5 14.28 69.14
    3320 151.1 18.7 106.92
    4120 160.2 19.38 125.53
    4320 155.6 18.36 127.75
    4760 145.9 17.34 133.36
    5200 142.1 16.66 141.78
    5600 136.1 17 146.75
    6000 130.1 15.3 147.5
    6280 113.5 13.26 137.19
    6560 105.3 12.58 131.28
    6760 99.2 12.24 129.06
    6880 33.8 3.4 13.67
    5120 13.5 1.7 12.47
    5120 12.8 0 12.72
    5000 12.8 0 12.22
    4840 12.8 0 12.03
    4680 12 0 11.31
    4400 12 0 10.89
    4080 12 0 9.83
    3640 12 0 8.78
    2880 13.5 0 7.44
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    Evap one is normally due to removing the EVAP vacuum source when doing a clean up on pipes... one goes into the TIP and the other into the top of the throttle body... if there is little or no flow (from lack of vacuum) detected by the ECU then it throws this fault..
    Your airflow is way too low... std S3 will do 170gs all day long... remapped then its nearer 200gs...
    The other fault code ...
    16502/P0118/000280 - Ross-Tech Wiki
    16502/P0118/000280 - Engine Coolant Temperature Sensor (G62): Signal too High
    Possible Symptoms
    Difficulties with starting a cold engine.
    Starting the engine when engine is warmish or warm, idle rpm immediately is 1200 - 3000 rpm.
    RPM at idle is irregular.
    With all engine temperatures idle rpm will often vary between 900 - 1000 rpm.
    With engine warm (90 °C) the engine temperature suddenly drops (70 °C) and slowly comes back to 90 °C.
    Bad acceleration during warm-up.
    Diesel Engines: Glow plug indicator may be on for a longer than normal time or at ambient temperatures where it shouldn't come on at all.
    Possible Causes
    The electrical signal coming from G62 is too low
    Wiring and/or connections faulty (short circuit?)
    Engine Coolant Temperature Sensor (G62) faulty
    Possible Solutions
    Check wiring and connections
    Check / Replace Engine Coolant Temperature Sensor (G62)
    Special Notes
    In many cars between MY 1995-2002 the G2/G62 had a bad reputation for failing often. The original G2/G62 sensor is black and the improved replacements are green.
    Suggests a faulty coolant temp sender and should be fixed really before chasing other issues as the ECU relies on this sensor for a lot of stuff..
    On the 65535 AWD fault, check the control unit plug and the rear diff earth strap..
    Haldex not working? No communication etc? Look inside
    <tuffty/>
    Scullies's Avatar
    Feb 2012
    Dubai
    1,240
    So would you say my MAF is on its way out? Could that be causing the hesitation at WOT.
    With the Engine Coolant Temperature Sensor, I dont get any of those symptoms, except the idle rpm is a little off, by about 20-30 rpm.
    But I will be replacing the G62 soon.
    My AWD system is working, I can feel it when Im in a corner also when I drive like a holigan and get the car to AWD drift, very slightly tho. I will have a look at the haldex over the weekend. Plan to fit my downpipe and decat if it arrives. Any advise on fitting this would be appreciated.
    Thanks for your help Tuffy, you like the ASN wiki
    Oct 2012
    6
    Did you get the car working whithout the hesitation ??
    i have the same problem but running non OEM Ecu whith Map sensor and no MAF
  1. My 1.8tq feels hesitant around 3000rpm on WOT
    By LSL in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th February 2010, 19:37
  2. 2.0 TDi Hesitant
    By TripleD in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th January 2010, 12:02
  3. Hesitant on boost...
    By warleydaddy in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd August 2009, 19:55
  4. Hesitant and Sluggish
    By trotman in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th January 2008, 08:02
  5. hesitant acceleration
    By kenny_boon in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th July 2006, 22:30
