Badger5Chris Nott
Results 1 to 16 of 16
Like Tree1Likes
  • 1 Post By actualeddie
Thread: Been told this but not convinced..how can I tell or not?
    Mar 2012
    Bradford
    56
    Alright guys,basically I have a 2000 8l s3 pre facelift apy engine code,I've owned it a couple of month,when I bought the car the guy claimed it was around 300bhp mark which I wasn't really expecting,but it does have all the usual mods,3"downpipe(I think) decat and resonated miltek,drilled air box and pipercross panel filter and remap(not sure which one but it's quite aggressive when turbo kicks in)standard inter coolers,but he also said it had ko4 turbo,is hard to see anything in the engine bay let alone seeing the turbo,is there any way of getting to it or seeing it without stripping the engine bay?
    Not really fussed if it's not I'd just like to know for certain if I'm going to order silicone pipes and stuff.
    Thanks guys
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,223
    It wont be 300bhp mate. Itll be around 250/260 with those mods if it does have those mods. Also all s3's come with ko4 turbos.
    Mar 2012
    Bradford
    56
    Cheers mate,I always thought it was the bam engine s3 that came with k04? Mines the apy 210bhp model,have I read wrong?
    Mar 2012
    Bradford
    56
    I wasn't expecting it to be 300bhp,think the guy was just saying that as a selling tool but I'm not fussed,I just wanted to know the car was fine as I travelled miles to get it.
    Sep 2010
    Devon
    756
    All s3's came with a K04...APY,AMK and BAM....
    Badger 5 tuned 340 bhp / 350 lbft sleeper
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    its probably a stage 1 map with no FMIC
    actualeddie's Avatar
    Feb 2012
    Waltham Abbey, Essex
    211
    Mine was sold to me with 267bhp with just an amd remap and forge dv. On paper i think thats possible at least
    S3SYD likes this.
    Mar 2012
    Bradford
    56
    Yes I was under the impression that just a remap would make around 260bhp on all the s3 8l engines,I defo do have the milltek,down pipe and decay as well as filter and remap,would the not make a few more bhp?
    Thanks guys
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    S3's make 240 to 260 hp on stage 1 software, 275hp is possible with stage 2 software, FMIC and Badger 5 TIP but it does vary depending on engine condition especially these days as they are getting old...
    <tuffty/>
    Mar 2012
    Bradford
    56
    Quote Originally Posted by S3 rpm View Post
    Thanks guys
    Decat...not decay,that's just rank! Idiot iPad keyboard!
    Feb 2012
    211
    Think stage 2 is customised for mods
    Mar 2012
    Bradford
    56
    Probably best getting it on the rolling rd to find out I reckon. What sort of bhp you reckon I should be getting,or could be getting with the mods I've mentioned?
    Thanks guys
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    Thanks guys
    Between 240 and 260 hp as mentioned... and don't take it as read what the dyno says either as this will be down to dyno lottery...
    I would make sure that wherever you take it either specialises in VAGs or at least knows enough about them to log whats going on in case of other issues... have seen loads of cars on the dyno with '260hp' only for them to be putting not much more than std power due to all sorts of reasons...
    Also, you won't make best power unless you are using some sort of premium fuel such as V-Power or Momentum... have had a few cars in that have loads of timing pull and make lower end of the stage 1 power range mostly due to using 95 ron fuel...
    Most stage 2 maps require you to run 98/99 ron fuel as it allows extra timing to be added to get the mid range increase stage 2's provide...
    <tuffty/>
    Mar 2012
    Bradford
    56
    Cheers for that tuffty,I'm not too fussed about getting more power for now I'm more bothered about getting on top of the car and getting to know it and make it reliable before more power is added,I've driven really alot of the 1.8t engined cars,tts,s3's etc and know that it feels way better than the standard stuff does.
    Thanks guys
    Rick @ Unicorn Motor Dev.'s Avatar
    Jan 2012
    Stockport, Cheshire
    748
    She won't be 300, you're limited by what the std turbo can flow. A big boost spike in the mid range will make it feel fast, i.e. the mid range pull.
    We're not too far away from you if you'd like it health checked
    Rick
    Unicorn Motor Developments. Bespoke Calibration and Remapping Services
    www.unicornmotordevelopments.com
    Jimgrim77's Avatar
    Nov 2011
    Clevedon, Near Bristol
    957
    Defo not 300.
    Ming Blue S3, Stage 3 Hybrid Turbo, Custom Map, Bosch 480 injectors, Custom TIP, Forge FMIC, 3" Downpipe, 200 Cell Sport CAT, Full Stainless, XS Power Mani, 6 Paddle Clutch, Red silicone hoses, LCR Brembo's, Forge 007p, KW Suspension Kit, Green filter, THS Mounts, 11mm & 16mm spacers, H&R Anti-roll bars, RS6 18" alloys, Michelin PS3's, Red Dog Bone Mount, Neuspeed quickshift, Boost Gauge, Aero wipers, LCR splitter, Forge Tie-bars, LED bulbs, Armrest, Custom TT pedals.
  1. Told To Remove DV
    By Craig Cull in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 30th January 2012, 09:18
  2. Replies: 2
    Last Post: 29th September 2011, 22:07
  3. Just been told my car can't be remapped?
    By Zonda_ in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st October 2009, 12:50
  4. Recall on the S3 - dealer just told me
    By Irish in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th August 2007, 10:55
  5. Just been told i need new ECU
    By griffin1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th April 2007, 12:45
