Volks AutosJMB Retrofits
Results 1 to 11 of 11
    Essflee's Avatar
    Mar 2008
    2,007
    Smile Audi S3 Battery dead'ish
    Hi,
    Does anybody know how much voltage is needed to start an S3, I bought a new battery last year because the old one had died, well now this one is giving me problems, went to start the car yesterday after not driving it for a few days and it didn't have enough juice to turn over, I'm guessing that something is draining the battery whilst the car is sat locked up, just been and bought a battery charger from halfords and when I hooked it up it's showing the battery as having 13.7 volts, after doing some reading up on the Internet I'd of thought this was enough to start my car ?
    Has anybody else had problems with getting a flat battery ? Looking for ideas on what could be draining it, only thing I've checked so far is the lights in the boot, make sure they're going out, which they are.
    Cheers for looking
    revo'd
    Jul 2007
    770
    If you say that its fully charged the its could be a connection.Check the terminals first and clean off any corrosion
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    Does the car have a tracker? That will drain a battery over a couple of weeks. I have to keep my Speedster on a trickle charger for that reason.
    Only problem I had with the S3 and battery was with an aftermarket iPOD connector for the stereo that was causing a current drain.
    Jason
    2001 Nogaro S3 (daily driver)
    1958 replica Porsche 356 Speedster (summer posing)
    1997 Seat Cordoba SX 16v (track day toy) replacing (t)rusty 1994 Seat Ibiza GTi RIP
    Essflee's Avatar
    Mar 2008
    2,007
    Quote Originally Posted by Mike B View Post
    The terminals look ok cheers
    revo'd
    Essflee's Avatar
    Mar 2008
    2,007
    Quote Originally Posted by jcs356 View Post
    I did wonder if it could be my phat box in the boot, it just plugs into the lead from the cd multi changer and there isn't a light on the box with the car switched off so not convinced its that.
    Im going to try leaving the car in the garage unlocked and see if that improves things, thinking it might be something to do with the alarm, see if I bm an rule that out.
    Going back to the charge, when I first plugged it in to charge it was showing 13.7 volts, however it only took 15 mins to charge and was showing 13.2 volts when finished, what's the lightly hood of a dodgy battery ?
    revo'd
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Are you sure your starter is not getting lazy...? needing a refurb/new one
    Essflee's Avatar
    Mar 2008
    2,007
    No Dave, starter seems fine, once I'd recharged the battery which took all of 15 minutes, the car started instantly on the turn of the key.
    revo'd
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    You could do with testing to see if there is something draining it, have you an aftermarket stereo? these can cause problems
    Crazypete00's Avatar
    Oct 2007
    266
    i've been having issues with battery drain. do you have a multimeter? you need one that has at least a 10A setting. then look up on youtube at a parasitic battery drain test.
    Doing the test you should find whats draining your battery - im in the process of doing the test now. so far ive narrowed it down to a cable in the fuse box on top of the battery. the cable marked in blue below is where i found my drain coming from, just need to find out what that cable feeds.
    sorry to hijack your thread, but does anyone know what that cable feeds?
    Squirrelofdoom's Avatar
    Feb 2012
    Surrey
    535
    Hi Essflee,
    I had similar battery drain issues. Check my thread out, there's some useful info in there:
    Xreg Imola Yellow S3 - Project post
    Essflee's Avatar
    Mar 2008
    2,007
    Thanks for the replies !
    After charging the car yesterday, jumped in it early this morning and car wouldn't start again, steering wheel took a pounding, lol
    Going to invest in a multimeter and see if I can find a drain, I've unplugged my phatbox in the boot to see if this makes a difference, when I do find the problem I'll post up.
    revo'd
  1. I think my Battery has had it! (Audi S3)
    By Poke13 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st February 2011, 18:44
  2. Advice Needed on 3.2 Battery Charger/Charging (Battery is dead)
    By Hellz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th March 2010, 17:48
  3. Audi A6 4F 3.0 tdi Battery Monitor
    By singhl in forum VCDS (formerly VAG-COM) forum
    Last Post: 26th April 2009, 17:32
  4. Battery Problems (Audi S3)
    By Vman in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th December 2005, 10:04
