EM TuningJMB Retrofits
    Mar 2010
    11
    AUM blown AGU replace?
    Ive been offered today a 2000 1.8t with engine code AUM but the engines totally shagged, But theres a working 1998 AGU engine at work just sat waiting to be put into something. So just wondered if theres alot that would need changing to make it run ok eg. ECU or pipework or is it a simple drop in and drive off? Any info appreciated cheers
    camscockle20vT's Avatar
    The stigs ugly brother
    Nov 2010
    1,673
    Short answer no it wont just drop in and drive. Find out what is wrong with the aum engine and swap the components over from the agu. But keep the ko3s turbo from the aum, the agu turbo is pants.
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,361
    drop the AGU in, it'll be fine.
    You'#ll just need to run all the sensors and ancillaries from the AUM, but that's no hardship.
    You will need to swap over the VVT tensioner and stuff also to keep that working, but again, if you're contemplating an engine swap, I doubt a VVT tensioner is going to phase you....
    Jan 2012
    21
    I actually happen to be in the process of doing the exact same thing. I have a wrecked AUM and can only get hold of an AGU at a decent price. If I run all the sensors and ancillaries from the AUM on the AGU will VCDS not come up with any faults once the change is complete?
    Thanks in advance for any replies that are helpful.
  1. AUM MAF on AGU?
    By sekenzo in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th April 2013, 19:50
  2. AGU or AUM engine
    By DAZ1985 in forum For Sale/Wanted - Audi Parts
    Last Post: 9th January 2012, 21:21
  3. Aum engine swop to an agu?
    By DAZ1985 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd December 2011, 12:30
  4. agu aum????
    By finny_quattro in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th June 2010, 19:13
  5. AGU vs AUM
    By nickrex in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th April 2009, 09:31
