EM TuningBadger5
Results 1 to 29 of 29
    Nick090884's Avatar
    Mar 2012
    rochester
    201
    Exclamation Serious problem less than 50 miles after have cambelt kit and water pump !!
    Hi ya Peep's
    Im after some much needed advice as i now there are a big handful of good lads on here. I had my cambelt tensioner pullies and waterpump and Aux belt changed two days ago and ive just this minute drove to the shop and theres a lound wining when the car axcellerates or revs. im gunna get them to pick it up monday im fuming at the moment and could do with some advice as to whats gone wrong and what to do if they try it on . im gunna struggle not to hit em as ive just brought a few months ago and laid out 300 quid for them to do it . i supplied the aux belt as they had to take it of to do the belt. it was a continental belt so wasnt a crap one. HELP PLEASE !!!!
    Aug 2010
    1,540
    could you take a video of the noise?
    beachbuggy's Avatar
    Surrey
    1,744
    I put my money on low PAS fluid.. Westy knows about this..
    Benjiman46's Avatar
    R-Tech Terrorist
    Feb 2012
    Worksop
    547
    Either low power steering fluid or the tards at the garage you had it done at have tightened the belt too tight lol
    1.8 litre porsche eater!
    R-Tech Terrorist Squad - 265bhp & 275lbft
    Nick090884's Avatar
    Mar 2012
    rochester
    201
    Quote Originally Posted by murran View Post
    Hi ya dude i can do in the morning weather is proper cack !
    Nick090884's Avatar
    Mar 2012
    rochester
    201
    Hi ya Guy's cheer's
    If it the Power steering Fulid how would this just go so low. the levels where fine when i took it to them. it wines when i move the steering wheel too.
    Nick090884's Avatar
    Mar 2012
    rochester
    201
    if the belts been done to tight shall i get them to change it cos the likely hood its been rubbing to make that noise .
    cheers
    Aug 2010
    1,540
    so when you load up the power steering its more noisy? is the level low? is it leaking anywhere?
    Nick090884's Avatar
    Mar 2012
    rochester
    201
    Right ive looked at the black power steering resirvior and had look in side and its below the black plastic mesh. if this is low could they have lost it when removing the bits to get to the cambelt? the aux belts running ok not rubbing. the wining noise has gone with it just ticking over. will go for a careful drive tomorrow . just see ya post mate . done look like it leaking but its hard to tell. i will go and have a go putting some pressure on the steering.
    Benjiman46's Avatar
    R-Tech Terrorist
    Feb 2012
    Worksop
    547
    Quote Originally Posted by Nick090884 View Post
    No mate, they really really shouldn't be touching that... It a can leak out of the seals on the steering rack over time, just refill it with ATF and see if the noise goes away. If not, they've done the cambelt too tight and they need to adjust it... If it's too tight for too long it'll snap, and if you're going fast enough when it does snap, you'll probably need 20 new valves :S
    Nick090884's Avatar
    Mar 2012
    rochester
    201
    Question
    Hi ya Ben and Murran. ive just been out its ok when the wheel is straight and noisey when under load. find it strange that its happened two days after them having it. its wet outside and had a little wheel spin when driving back this would upset the rack in any way would it ? fingers crossed its not leaking. wouldnt it be moved to do the belt ?
    Cheers again ( you have all calmed me down at bit)
    O where im i filling this up to is there a marker as i couldnt see any. is it ok just to top up not sure whats in there. any recomended makes or types i'll poop to halfords in the morning before i send it back.
    Jul 2007
    London
    3,235
    Buy genuine power steering fluid not Halfords ATF as you'll damage the steering rack ! The genuine PAS fluid is under a tenner in dealer...
    FOR SALE:
    Nick090884's Avatar
    Mar 2012
    rochester
    201
    Quote Originally Posted by adamss24 View Post
    Nice one fella. will wait til tomorrow then and pop down there.
    Benjiman46's Avatar
    R-Tech Terrorist
    Feb 2012
    Worksop
    547
    It's the same stuff pal lol
    beachbuggy's Avatar
    Surrey
    1,744
    Quote Originally Posted by Benjiman46 View Post
    Sorry don't agree here. You have to undo/ remove pas reservoir to get to engine mount and Cambelt, so they would have had to touch it. You will nearly always loose a bit of fluid if your not careful just one of this things.
    Also almost positive you can't over tighten the Cambelt. The tensioner provides the correct
    tension
    BENJAMIN's Avatar
    Mar 2011
    471
    Quote Originally Posted by beachbuggy View Post
    tension
    Agreed, p/s reservoir requires a pipe removing to gain access to the mount, you may lose some fluid.
    Adamms24 is correct, vag do not use normal ATF as p/s fluid, they use a specific mineral based fluid. Using the correct fluid is imperitive to keeping the seals intact.
    You cannot over tension the cambelt, an automatic hydraulic damper sets the tension. Never seen a 20v belt over tensioned, only under tensioned where the damper has failed.
    Hope that helps.
    Nick090884's Avatar
    Mar 2012
    rochester
    201
    cool nice one fella's. i will talk to the garage in the morning andget them to sort it. i will make sure they get the correct fulid. also having a look this morning ive found that the bottom left hand sheild /engine protector was on the floor scrapping so that was part of the noise.
    the tossers my car is in A1 condition they should of respected my car and they clearly havent. they will be getting a ear full.
    Cheers again lad's
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,505
    Agree with the above, mineral oil is VAGs power steering fluid, and cambelt can not be over tight due to hydraulic tensioner used.
    I thought it might have been a badly fitted camcover!
    Nick090884's Avatar
    Mar 2012
    rochester
    201
    Quote Originally Posted by jojo View Post
    Hi ya mate, good to have a few people all say the same. the cam cover is on ok. think most the noise was from the undercover on the floor couldnt see that last night as it was too dark. the noise isnt as bad now but gunna get the garage to fix it tomorrow even if i have to get the fulid myself and charge them for it. im gunna demand they check it all over as they didnt first time round , otherwise they would of seen the protector wasnt fitted correct or fixed and that the fulid level was low. wont be going there again !!
    willowsdad's Avatar
    Sideways
    Oct 2011
    Medway-Kent
    1,022
    Where did you get it done in the end mate? And keep us updated so we know whether to avoid them or not. Hope it all gets sorted for you.
    A3 3.2 Quattro Sport
    Nick090884's Avatar
    Mar 2012
    rochester
    201
    Quote Originally Posted by willowsdad View Post
    Hi ya dude i got it done at sliverback proformance in the end because a load of people i know have said they was good. im hoping it will get sorted angot a good idea that it wasnt done by the actually bloke i was recommended to. think it was a young ish lad.
    I wish i took it to AMD in essex now . no way i am letting them do anything else !
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,273
    Worst feeling in the world. Rev the car, loud screeching grinding noises on the belt side of the engine, shut off the engine thinking it's all ruined, heart sinks.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Nick090884's Avatar
    Mar 2012
    rochester
    201
    Quote Originally Posted by Westy View Post
    i know man ! heart went cold and jumped a beat. there wont be any damage to the car will there ? just top up n get it double checked jobbie. still feel crap, until i get it sorted that will be the only thing on my mind. my cars are like my kids.
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,897
    Did they let him out the cage to do it
    Nick090884's Avatar
    Mar 2012
    rochester
    201
    Quote Originally Posted by voorhees View Post
    PMSL! Fooking had to be one they let lose on it the way the cars been treated !
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    I can't stand taking my car to a garage that doesn't know about VAGs.
    You'll usually end up with broken and missing clips all over the place. Snapped trim and connectors where they didn't know how to remove something so just levered it off with a screw driver.
    Or is you're really unlucky they'll use some random coolant or generic fluid to top up something special that VAG concocted.
    Do you reckon random/independent garages look up the torque values for all the nuts and bolts they undo or do they just do them all FT?
    Liam
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
  28. #27
    Nick090884's Avatar
    Mar 2012
    rochester
    201
    Cool
    My faith in them has been restored. phoned them this morning he sorted it straight away . looks like saturday night i hit a speed bump and dislogded the undertray coursing it to rub on the aux belt. he sorted that and topped up the powersteering with the correct fulid. said sorry and that the fulid should of been topped up. its was only a few mil of fulid short. all sorted happy man!
    spoke to him about a few bit's, had a quick dribble at the highly modded range of motors there and off i went.
    I think i would go back there again when i need a few bit done, if i dont do them myself.
    Nice one Silverback ! ooh ooh
  29. #28
    Chugger
    North Devon
    2,716
    Wow, hopefully they dont read this thread then :P Else they'l be rubbing dog ****e into your carpets next time round
    Just for reference, it is recommended that you use genuine power steering fluid, but vw/audi would have you using there own distilled water in the washers... but fact is you can use stuff from halfords if you find yourself with no choice (late night or weekend job)... just have to use their hydraulic fluid rather then their specific P/S fluid... iv had it in mine for 2 years will no problems and used it in my other vag cars which are still going strong with the same fluid
    57 A3 2.0 TDI Sportback (140)
  30. #29
    Nick090884's Avatar
    Mar 2012
    rochester
    201
    Ha ha hopefully they dont. they should of still double checked everything . i double check and triple check and check again when im at work on my fire alarm panels. ive always had a methodical way of doing things to ensure its done correctly
    Happy days anyway ! few more bits to do then on to a few little mods
  1. S3 (8L) Cambelt change with new water pump
    By Alex C in forum Parts Requests
    Last Post: 2nd February 2010, 14:40
  2. where to buy a cambelt kit and water pump
    By gibo in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th January 2008, 10:25
  3. cambelt and water pump
    By dantheman1986 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th April 2007, 13:01
  4. Cambelt kit and water pump - Where to buy?
    By awmw in forum Diesel forum
    Last Post: 14th November 2006, 10:58
  5. Cambelt and water pump
    By GarryA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th April 2006, 19:47
