AH FabricationsEM Tuning
    Apr 2012
    Wiltshire
    164
    knocking noise from engine
    Took my rocker cover off last weekend, cleaned it up and put a new gasket on with a little high temp silicon sealant as it was leaking befor. Now every morning when i start the car up, when the engine is cold there is a loud knock, knock, knock from the rockercover. it goes after around two minuets of running. Any ideas? its only happened since i took the rocker cover apart
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    I would be wipping that cover off quickly.... left a tool in there? or the silicone has blocked an oilway?
    Apr 2012
    Wiltshire
    164
    well i took the rocker cover off again and it all looks in order except on the cams, where it is there highest point on there tip the shiny colour has gone and looks a bit pitted. Is this a major problem? also took the sump off cleaned that out and changed the pick up feed. fresh oil and oil filter. When the car is started in the morning its a horrible knock from the top end which just almost goes after a minute. could this be a hydrolic lifter?
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    741
    Id seriously not run the engine until you have this properly looked at, something is seriously wrong and you risk doing a whole lot of damage if its not fixed pronto.
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
    MingeBlue's Avatar
    Feb 2008
    112
    what was it in the end ? Ive started to get a knock on startup but goes after a couple of mins.
    2002 A3 1.8T
    Apr 2012
    Wiltshire
    164
    Quote Originally Posted by MingeBlue View Post
    Well in the end the problem was coming from one of the conrods as it was a s shape, the pistons had very bad valve damage on them too. It looked like the previous owner snapped the cam belt and threw a new head on the car and sold it quick to me. From there onwards one of the rods must have been slightly damaged slowly bending more and more every time i used it. The noise would have been piston slapping about untill everything had warmed up and exspanded. All fixed now tho nearly 5k later
  1. knocking noise coming from engine (s3 8p)
    By dave_ph in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd February 2013, 14:33
  2. S3 knocking noise?
    By gynads in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st November 2010, 17:45
  3. Problem number 1 of ownership! Grinding noise and knocking noise help!!!!
    By gaznogaro2003 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th July 2010, 09:17
  4. Knocking noise???
    By Ads in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th August 2009, 14:51
  5. knocking noise in A4 TDI Engine
    By Paulw in forum Diesel forum
    Last Post: 31st March 2007, 18:48
