Results 1 to 16 of 16
Like Tree1Likes
  • 1 Post By Vwdan80
Thread: boost gauge help
    Apr 2012
    swindon
    20
    boost gauge help
    Hi I went to wire my boost gauge in today was gonna do it off the headlight switch but the loom isn't long enough for me to pull out and work on. Any ideas as to where else I could wire from (pics please am rubbish with this sort of thing) or how can I get a more slack on headlights loom cheers Derek
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,231
    anything which comes on with the headlights. i've ran mine off the light near the cig lighter (lights up the area under the centre console)
    Audi A3 8L 1.8T breaking.
    front bumper, impact bar, slam panel, full engine and loom sold.
    everything else for sale.
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    I ran mine into the air vent light. Mine has illuminated vent scrolls.
    MODS - Custom Code phase 1, 007p DV, various powerflex bushes, EBC grooved and drilled - red stuff pads, N249 deletion. Badger5 V2 80mm TIP. Scorpion backbox + custom centre section, LCR front splitter, Jetex Fr-08001, R32 rear ARB, Forged IE rifle drilled rods, 20mm rear & 15mm front spacers.
    TO DO - Coilovers, adjustable tie arms, DP/mani/decat, FMIC and new remap
    Apr 2012
    swindon
    20
    I don't have illuminated vent scrolls and I dont have a light under my center console well not one I can find anyway
    Nov 2011
    lincoln
    46
    do u have a headlight ajustment switch, i used that on m4 a4 as it illuminates when light on.
    Apr 2012
    swindon
    20
    Yeah but as its too short for me to be able to work on
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,231
    why not just make the wires longer. so your able to connect to something easy to get to ?
    actualeddie's Avatar
    Feb 2012
    Waltham Abbey, Essex
    211
    I put mine in the vent to the right of my steering will and wired it up to the headlights switch. Where you aiming at fitting your gauge?
    Vwdan80's Avatar
    Nov 2011
    South east
    100
    Hi just take the lower dash panel off under the steering wheel to get to the headlight switch loom better
    actualeddie likes this.
    2002 s3 silver, BAM, lcr Brembos ds2500 pads, Braided hoses, forge 008 dv, stack boost gauge, power flex dog bone bush/wishbone bushes, forge boost hoses, B5 tip, B5 remap, toyo fmic
    Apr 2012
    swindon
    20
    It's in the vent next to the headlights switch I pulled the headlights switch out and the block that connects to the back only just reaches the hole so for me to work on it I need to be able to get my hand in the headlight switch recess I am gonna extend boost gauge wires anyway cod they are only about 10cm long anyway
    Apr 2012
    swindon
    20
    Quote Originally Posted by Vwdan80 View Post
    Was just replying when u wrote that will have a loooook in the mornin
    Feb 2012
    211
    i stripped the wired half way up from the switch and taped them on, would have soldered but couldnt find an iron.
    Vwdan80's Avatar
    Nov 2011
    South east
    100
    The lower panel comes off easy and will give you loads of room to work
    Feb 2012
    211
    Quote Originally Posted by derek84 View Post
    How'd you get the vacuum tubing in without taking the panel off?
    Apr 2012
    swindon
    20
    Quote Originally Posted by actualeddie View Post
    I ain't done that yet I just want to make sure I have everything clear in my head Before I start tryin to wire in properly Cos sods law if I had plumbed it in then found out I couldn't wire it where I would of liked
    Feb 2012
    211
    Fair enough. Once the covers off from under the wheel it should be easy. 3 screws i think 1 in the fuse box
  1. Boost leak, Weak Actuator or boost gauge?
    By DaveA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th July 2011, 13:51
  2. Replies: 0
    Last Post: 17th January 2011, 21:00
  3. Boost gauge only reads negative boost?
    By garyrmills in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th October 2009, 21:45
  4. Boost gauge
    By G's S3 silver 2001 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th February 2009, 13:13
  5. boost gauge
    By Danielson in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th September 2004, 15:56
