AH FabricationsChris Nott
Results 1 to 7 of 7
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,828
    change fluid when doing disks & pads
    Ordered some rear disks and pads as mine need changing. Do I need to change the fluid as well or bleed the brakes?
    Word!!!
    My A3/Martys Golf would smash that, and this guys £7000 GT9743 supercharged love machine.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,041
    You shouldn't need to bleed the brakes but you will need to beg, steal or borrow a piston windy in tool as the rear pistons need winding in... be prepared to take some fluid out of the reservoir too as the level will raise as you wind them in...
    Fluid should be changed every 2 years anyway so if you haven't already then do it anyway...
    <tuffty/>
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,828
    Tuffty, my engine guru, thanks.
    I'm preety sure I cam hand the disks and pads change. I want to bleed the brakes tbh as I have just got some motul rbf. Haven't had a look at the master cylinder yer but I know this needs bleeding last. Is it straight forward to do?
    Word!!!
    Jun 2007
    38
    Its never going to hurt to change the brake fluid. Especially if you drive the car hard. Or if you just don't know when the last time it was done was. I've done some changes where the stuff thats come out has been horrific. Your half way there and brake fluid isn't expensive so why not?
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,828
    Yeah your right mate, will have a look at the m/s and work.it out. Cheers
    Word!!!
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    My advice is go change your fluid. Especially if you don't know when it was done last.
    This is what I found inside my motorbike when I bought it. (and that's diluted with some clean fluid too)
    There was no mention of a brake fluid change on my bike in the service book and it was 5 years old when I got it.
    Liam
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,828
    Wow thats some nasty stuff. ok you've beaten me into submission, i'll do it
    cheers lads
  1. Disks & pads
    By mitch2575 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th March 2012, 08:27
  2. Brake Pads & Disks 2004 8p
    By shakt1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd November 2010, 14:54
  3. what new disks & pads to get as swift cover now says i can fit any !! :)
    By subaru swift in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th September 2010, 12:47
  4. DIY Front Pads & Disks Replacement - Tool Checklist
    By vanilla_ice in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th December 2007, 20:27
  5. Brake/Clutch Fluid & Engine Oil & Disks/Pads etc
    By cha1n in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th November 2007, 13:13
