EM TuningAH Fabrications
    Mar 2011
    buy st edmunds
    65
    s3 subframe swap
    hi guys and girls how hard is it to swap an s3 2000 subframe?
    if i swap will be doing on stands on the driveway and yes i can use a spanner but just want to know if its going to cause me any probs?
    im guessing just wishbones,rack and bottom mount to dissconnect? maybe arb etc?
    any tips greatly appreciated
    liquids3's Avatar
    Jul 2010
    Bristol
    933
    If you have abit of knowlege you will be ok,not that hard really,just be carefull under axle stand's,sub frame is'nt very light so two man job to hold and take off,id say while your at it change your anti roll bar for an uprated one,otherwise when you do want to uprate it you'll have to drop the frame again,and you cn leave the wishbones in just drop of the ball joint,dnt forget to take of the esp bar on nsf wishbone if you do it that way though,good luck.
    Audi S3- 1.8T Quattro
    Liquid Yellow
    Audi R8 Rims
    Its never finished!
    Feb 2011
    109
    As said easy enough, I did mine on my own on the drive, just used a jack to lower it and lift back up. Change the rack bush to a nylon one at the same time. Also order new subframe bolts as they are stretch items, you need 4.
    Mar 2011
    buy st edmunds
    65
    just a quick one are all 8l s3 subframes the same before i buy one? mines an early 1999/2000 and found a 2002 subframe i could get cheapish?
    Feb 2011
    109
    Think so yes, I used a MK4 Golf one, the only diff was a lack of holes for lower brace, but you can add those if you wish.
  1. Rear subframe
    By S3Zek in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st April 2012, 17:13
  2. 8l 1.8t front subframe
    By a3turbosteve in forum For Sale/Wanted - Audi Parts
    Last Post: 23rd March 2012, 22:02
  3. S3 Subframe ????
    By Jacko4130 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th January 2010, 20:46
  4. S3 subframe question
    By vegas in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th October 2009, 23:47
  5. Subframe bushes A4
    By AndyC in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th June 2007, 10:59
