EM TuningVolks Autos
    May 2011
    26
    Head, main and big end bearing tightening sequences
    Hi, does anyone have the tightening torque/ angle figures and sequences for the head bolts, main bearing and big end bearing caps please?
    Adam
    May 2011
    26
    For an s3 I probably should have mentioned...APY motor,
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    Big end bearing caps are 22ftlbs and then 1/4 turn. (if there standard rods and bolts).
    MODS - Custom Code phase 1, 007p DV, various powerflex bushes, EBC grooved and drilled - red stuff pads, N249 deletion. Badger5 V2 80mm TIP. Scorpion backbox + custom centre section, LCR front splitter, Jetex Fr-08001, R32 rear ARB, Forged IE rifle drilled rods, 20mm rear & 15mm front spacers.
    TO DO - Coilovers, adjustable tie arms, DP/mani/decat, FMIC and new remap
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,557
    Standard OEM head bolts are 40nm (go round twice), then 60nm (go round twice) followed by 180 degrees but do that in 2 x 90 deg rounds...
    Reason for going around twice on initial torque is that as you work out through the bolts the centre bolts will go loose again as the head gasket compresses... no need to check the 90 deg rounds...
    Head bolt sequence is the opposite of the diag in this post
    VWVortex.com - FAQ : Cylinder Head & Camshaft Removal + Re-Installation
    For loosening head bolts you start from the outside and work in, tightening is start from the centre and work out...
    As above for std rods but if using after market uprated rods that use ARP bolts you MUST read the instructions.... ARP bolts are typically 55ftlbs using ARP assembly grease and you tighten to 55ftlbs 3 times (loosening them off each time) 3rd time being the final tightening...
    Not done a crank yet so not got anything for that but vortex should have some info... again... if using ARP studs then follow the instructions
    <tuffty/>
    May 2011
    26
    sweet cheers guys, the head bolt ones tally with what the instructions with the gasket say but wanted to double check, will look on vortex for main bearing info,
    cheers
  1. big grill front end parts
    By gizm0 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th July 2010, 14:16
  2. Torque setting for crankshaft main bearing caps + crank pulley bolt please?
    By Andrew@A.L.D in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th March 2010, 20:15
  3. What would get bent, top arms or main bearing housing?
    By Rhencullen1989 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th November 2009, 21:16
  4. PRICE OF BIG END BEARINGS
    By 20vtmk3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th March 2008, 19:26
