EM TuningChris Nott
Results 1 to 16 of 16
    Black 1997 Audi A3 1.6
    63
    Strange problem, revs going up and down and engine cutting out while driving!!
    For the past two weeks my car has developed a major problem. While driving, the engine will rev to 4k from 2k, back down to 1k and sometimes it stalls. It's not a small drop in revs but a major drop that causes the car to jerk. The car will even stall and randomly start a split second after!
    Any ideas guys?
    camscockle20vT's Avatar
    The stigs ugly brother
    Nov 2010
    1,673
    Get it checked on vag com for fault codes. Id suggest checking the pipes under the inlet manifold and give your throttle body a clean and reset it. Hope this helps.
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    Could be a split vacuum pipe, like said above, check under inlet.
    1999 APY S3 Imola Yellow
    PS3: Broady_11
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    9,640
    Defo sounds like a piping issue in the engine bay.
    Nov 2010
    1,673
    This thread has jinxed me my car has just cut out at low revs. First thing im going to do is clean my throttle body.
    Nov 2010
    1,673
    This thread has jinxed me my car has just cut out at low revs. First thing im going to do is clean my throttle body since i know my pipes are all fine.
    Nilz's Avatar
    Apr 2006
    9,640
    Let us know how you get on dude!!
    Apr 2011
    Dublin, Ireland
    564
    Faulty MAF
    B5 v1 Tip, Relentless v2 Manifold, Beach Buggy Hybrid, Pipewerx D.P and cat bypass, Miltek resonated cat back, AH Fabs v2 Intercooler, S2000 Filter, 83mm 9.5:1 CP Pistons, Brute Rods, Bosch 550cc Injectors, Oil Catch can, N249 delete, B5 Phenolic Gasket.
    H&R Springs, Koni FSD Shocks, s3dave's rear tie bars, LCR Brembo's, 18" ttrs alloys, replaced all suspension bushes, 15/20mm spacers front/rear.
    Now just waiting on my B5 exhaust manifold as the Relentless is goosed.
    63
    Could engine sludge cause this problem?
    63
    Ok the car has now started backfiring, like a huge pop/bang when driving, what is going on??
    Nov 2011
    Newcastle
    214
    Sounds alot like your MAF to me. Try disconnecting it and if if there's any difference. If theres not then it deffinatly if the MAF.
    The backfiring may be caused by a faulty MAF sending too much fuel through the system.
    63
    Quote Originally Posted by L33h View Post
    Definitely not the MAF, I disconnected it and the engine struggles to stay running.
    Any more ideas? I haven't had the car serviced in ages which doesn't help. Spark plugs haven't been changed for at least 17,000 miles??
    Apr 2011
    Dublin, Ireland
    564
    The car will not run with the maf disconnected. Sounds like a similar problem I had on another car which turned out to be faulty maf's.
    63
    Quote Originally Posted by IrishDave View Post
    But surely me disconnecting the maf and the engine struggling more so than when it's connected means that it is not the maf?
    Jun 2003
    World of my own
    9,813
    Yes if its worse or the same with the MAF disconnected then its NOT the MAF. The car should run fine with it disconnected
    Alex Turner
    63
    Quote Originally Posted by AndyMac View Post
    Maybe it's the head gasket? Started to lose some coolant too and slight mayonnaise on the oil cap.
  1. 1.8T 225 BAM Engine Cutting out! Air Mass problem? PLEASE HELP!
    By tjkherz in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th August 2011, 17:27
  2. high pitch noise when driving? it gets higher pitched with engine revs
    By danonline in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th March 2011, 19:23
  3. Revs dropping and cutting out
    By Andrew@A.L.D in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th November 2010, 13:31
  4. strange revs problem
    By ex_scoobydoo in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th September 2010, 14:25
  5. Strange engine revs issue? And another thing too....
    By JJBS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st December 2008, 10:34
