Badger5Sky Insurance
    Mar 2010
    34
    Anybody used Vagcom lite on the S3?
    I bought a cable and sofware from ebay but can seem to get it connected, "No response from controller" is all i get?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    Have you tested the lead in the options so VCDS can see it?
    <tuffty/>
    Mar 2010
    34
    <tuffty/>
    Yes tested on com 2 and it says ok?
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,087
    When I use mine, I have to go through all the com ports and it normally comes up on COM3, I sometimes have to take the lead out and put it into a different USB port, then try it again.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    Quote Originally Posted by wilcog33 View Post
    Make sure the 'boot in intelligent mode' is switched off... could cause issues on ebay leads iirc...
    <tuffty/>
  1. can i do this with the vagcom lite
    By skinz in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th October 2011, 16:46
  2. vcds lite
    By Jama665 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th June 2011, 16:54
  3. using VCDS Lite
    By Garber in forum VCDS (formerly VAG-COM) forum
    Last Post: 4th May 2011, 21:04
  4. vagcom or not or mabie just the vagcom lite
    By L3WJX in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st February 2011, 22:17
  5. VCDS-Lite
    By voteforpedro in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th May 2010, 20:53
