Sky InsuranceVolks Autos
    Dean_T's Avatar
    May 2004
    West Mids
    523
    removing front seats
    anyone know how to remove the front seats?
    i need to get the passenger seat out tomorrow and maybe the drivers too
    both seats have air bags and if im seeing them correctly, the connectors run from the centre of the car - obviously these will need to be removed
    any ideas how i get the seats out though?
    TIA [img]/ubbthreads/images/graemlins/smile.gif[/img]
    Re: removing front seats
    Good luck
    I thought i would pull mine out when i got it to give a good clean of the carpet but what a pig
    Any way did not get round to it after all to much hassle
    2x nuts at the front of the runners and 2 at the rear
    I would disconnect the battery for 30 mins then remove plugs and pull out seat
    Beware bloody Heavy
    Hope this helps
    Nathan
    Dean_T's Avatar
    May 2004
    West Mids
    523
    why do you recommend removing the battery for 30 mins?
    something to do with the airbags?
    imported_Wicked666
    it will get rid of the charge in the airbag so it shouldn't go off. Why would it go off though if you mess with the seat? Used to rip my seats in and out the saxo and just unclipped the airbag cable no probs.
    Numptie of the highest order
    Jun 2004
    Crowthorne, England
    2,512
    see the below link for more info, I managed to do it so it can't be that hard, recommend if your doing it one your own cover over the door sill as you'll probably want to rest it there before carrying it further.
    http://www.audi-sport.net/ubbthreads/sho...true#Post158707
    cleaning worked a treat, and you can get the replacement trim bits of plastic for not much money from either the dealers or vagparts, can probably post all the part numbers if you need them.
    suggest doing it when warm as ess_three said as it's a *****.
