Chris NottVolks Autos
Results 1 to 10 of 10
Thread: Xenon help
    rob irl tdi's Avatar
    Jul 2010
    241
    Xenon help
    I have a pre facelift s3 that gave off just a normal yellow light. So I replaced the bulbs with new xenon ones and the same is happening.
    They are white when you turn them on then when they warm up they are like a standard dip yellow.
    Has anybody had this problem before ? Possible ballast issues??
    2001 S3
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    What power did you fit? 4300k etc?
    MODS - Custom Code phase 1, 007p DV, various powerflex bushes, EBC grooved and drilled - red stuff pads, N249 deletion. Badger5 V2 80mm TIP. Scorpion backbox + custom centre section, LCR front splitter, Jetex Fr-08001, R32 rear ARB, Forged IE rifle drilled rods, 20mm rear & 15mm front spacers.
    TO DO - Coilovers, adjustable tie arms, DP/mani/decat, FMIC and new remap
    actualeddie's Avatar
    Feb 2012
    Waltham Abbey, Essex
    211
    mine are yellow when i first turn them on and within a second switch to blue, like a colour filter moves over it
    Nick090884's Avatar
    Mar 2012
    rochester
    195
    Hi ya fella, mine do this and ive just ordered new bulb's but there 6000k rather than a lower frequeny, hope ive not got the same issue when i change then you can get the ballast's oem and other on ebay from £30+.
    Jul 2010
    241
    I ordered 4300 originals. Turn on in perfect white but disappoint when warm.
    Are ballasts that cheap? Maybe if I bought 1 to try it 1st it might improve
    2001 S3
    Nick090884's Avatar
    Mar 2012
    rochester
    195
    Quote Originally Posted by rob irl tdi View Post
    4300k are not as white as higher k's that are on as standard now days, it may seem yellow compared to other road user's xenon's. i should have my bulbs soon so i will let you know before you go spending any more cash on bit's.
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,512
    4300k is the standard as its the xenon with the highest lumen. Your lights may be discoloured because of your lens. I've got a great link to read for you... The Audi TT Forum :: View topic - Anyone replaced their Xenon bulbs?
    Nick090884's Avatar
    Mar 2012
    rochester
    195
    Quote Originally Posted by Gops View Post
    Great link dude. the lens could be the problem if rob's are in a poor state the light doesnt go any where ! there's a good few kits online with amazing result's. Also a few youtube video's .
    Jun 2011
    Wellingborough
    1,127
    if you need OEM type bulbs in 6000k or 8000k i can supply these..
    Upgraded Xenon bulbs - D1S, D2S, D3S
    £20 posted with a year warrenty
    Bi Xenon Projector kits starting at £79.99 per pair.
    EM Tuning Lighting.
    Nick090884's Avatar
    Mar 2012
    rochester
    195
    Hi ya i put in my 6k's today and there less yellow than my standard ones were with a real slight hint of blue. there fine and get brighter when they warm up as there ment to. i dont think it would be the ballast as it would proberly just not work. also like i said before alot of road user seem to the higher kelvin's now days and that might make them seem more yellow to you.
  1. how can you tell the difference between xenon and bi-xenon headlights.
    By a3_sline_tdi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st October 2010, 00:16
  2. Single Xenon to Bi-Xenon upgrade?
    By SuperPuper2000 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th April 2010, 23:57
  3. From 2004 Xenon to 2006+ Bi-Xenon, Can it be done?
    By Joe90k in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th February 2010, 00:34
  4. Xenon or Bi-Xenon, whats the difference???
    By PTTM in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th December 2008, 18:13
  5. Xenon-Plus retrofit to normal Xenon
    By shaheed in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th December 2006, 00:41
