EM TuningMonster Motorsport
Results 1 to 20 of 20
Like Tree1Likes
  • 1 Post By Dani_B19
Thread: 0 Boost.
    Feb 2012
    70
    0 Boost.
    The S3 seems like it hasn't got a turbo. It was Boosting fine earlier and was pulling really strong and now it feels like I've got back to my old 1.4 golf.
    I've disconnected the MAF and still runs exactly the same, checked all the breather lines for splits etc (The one's under the inlet manifold were replaced quite recently) and from I can see they are all still intact as well as all the main hoses. Could I be dealing with a big air leak?
    This happened to me the other day but then all of a sudden I had boost again, could mine be flickering in and out of 'limp' mode?
    Anyone been in a similar situation?
    camscockle20vT's Avatar
    The stigs ugly brother
    Nov 2010
    1,673
    Is it remapped?
    Feb 2012
    70
    Quote Originally Posted by camscockle20vT View Post
    Is it remapped?
    It's not remapped
    Nov 2010
    1,673
    Ok dude, id suggest getting it on vag com/ross tech to see if there are any fault codes, before throwing money down the drain.
    Feb 2012
    70
    I'm off working abroad next week so I'l have to sort it when I'm back. Just not nice knowing you will return to a dud car.
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    No engine management light?
    Audi A3 1.8t AUM
    Forge 007p, Pipercross Panel Filter, Eibach Prokit 35mm drop, EBC Green Stuff Pads
    Groved Disks, HEL Braided Brake Lines with Dot 5.1 fluid.
    Creation Motorsport Silicone TIP,
    N75 hoses, DV Hose & 10mm Rear Wheel Spacers
    Powerflex Rear Beam Bushes & Diesel Dog Bone Bush
    8k HID Kit, 8k LED Side Lights, 8k Number Plate LED
    Feb 2012
    70
    No Engine light, Idle is a bit floaty but only very very little. Smooth power through the revs just no turbo kick at all
    Pushing the limits..
    Jan 2011
    Australia
    1,316
    Add Sevv on Facebook
    mate id check it on vag com first , check the boost pipes going from the DV to the hard boost pipe and your DV, check also your hard boost pipe, and i would suggest checking on the turbo its self
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,235
    Limp mode.
    Benjiman46 likes this.
    actualeddie's Avatar
    Feb 2012
    Waltham Abbey, Essex
    211
    It would sound like a woosh of air all aorund you if the orange/red pipes come off, at least it did with me
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    What's your location bud? There might be someone local to you that can scan it
    marshall-12's Avatar
    Apr 2012
    203
    i had this problem with my old golf gt tdi.
    no turbo at all, i checked everything these guys have checked, even took pipes of the turbo to check the blades etc thinking the turbo had gone, plugged it into vagcom got some stupid codes with reason i had never heard of lol
    sent it to a mates garage, to find the cam belt had skipped a tooth or 2 and the tensioner was on its way, and causing the car to go into 'limp' mode every time i started it up.
    my advise if it isnt anything simple, send to a garage where you have warrenty cause starting it up a load of times could make it worse, and if my cam belt had snapped... thats big money lol.
    but still, could be something simple.
    UpperClass Nerds ..
    ShaunS3's Avatar
    Yorkshire & Humber Rep.
    Mar 2012
    West Yorkshire
    891
    Quote Originally Posted by actualeddie View Post
    Which are the orange/red pipes? Where are they located?
    Feb 2012
    211
    orange/red pipe is at the back of the engine, goes down into the top of the turbo, OEM is known to go; mine went recently. comes of the metal pipe that goes around the left side of the engine
    Audi A3 TURBO HOSE 58.34 at Motorsport World
    Benjiman46's Avatar
    R-Tech Terrorist
    Feb 2012
    Worksop
    547
    Limp mode.
    +1
    1.8 litre porsche eater!
    R-Tech Terrorist Squad - 265bhp & 275lbft
    ShaunS3's Avatar
    Mar 2012
    West Yorkshire
    891
    Audi A3 TURBO HOSE �58.34 at Motorsport World
    I do get some boost pressure, but it feels as though when it's up to a decent pressure, it leaks out and causes a loud hissing noise from the engine bay. Mine is stage 1 mapped with an OE airbox (upgraded panel), forge tip and a (new/replaced) Forge 007p that is 2 months old. Thought it was the DV but i have swapped it and the power loss is still there.
    Feb 2012
    211
    if its off slightly you get a hissing noise, take it off and have a look for wear. Its a 10min job on and off. I used the hairspray trick around the rim of the red pipe when refitting it.
    ShaunS3's Avatar
    Mar 2012
    West Yorkshire
    891
    Cheers pal, will have a look tonight after work. I presume the hairspray trick is to act as a sealant to prevent it slipping of again?
    Shaun.
    Feb 2012
    211
    yea thats right, also found it slips on easier when wet too
    Feb 2012
    70
    Sorry for the late reply.. Who ever said limp mode give yourself a shiny.
    It goes in and out quite a lot. Car has properly died now and sounds haggid on turn over, oh the joys of s3 ownership.
  1. boost fluctuation at low revs (p1200) boost control valve fault code
    By 4rings in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th September 2011, 07:28
  2. Boost leak, Weak Actuator or boost gauge?
    By DaveA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th July 2011, 13:51
  3. Replies: 0
    Last Post: 17th January 2011, 21:00
  4. Boost Issue - Boost Pressure Regulation: Control Range Not Reached
    By RobinA3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th June 2010, 16:30
  5. Max Boost Safe Boost Pressure Rating?????
    By R31LLY in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th October 2009, 22:04
