Sky InsuranceJMB Retrofits
    Apr 2012
    93
    S3 conventional brake bleeding???
    hi all. is it ok to bleed the brakes the conventional, the normal way, on my 1999 s3? or will i need to take it to a garage with an easy bleed meachine? thanks in advance..
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,559
    As I said in your previous thread... no... use a pressure bleeder like Gunsons Eezi Bleed which will cost you about 15 quid tops from Halfords or eBay
    <tuffty/>
    Apr 2012
    93
    i no m8, but some one eles on hear said yes it was ok to bleed the normal way.. thats why i asked again.. you say no and he said yes, i just wanted a few more views. thanks.
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,559
    no mate... conventional method risks damage to the master cylinder which is a 200 quid part from Audi...
    Tbh you will get a better result with the Eezi Bleed... make sure you don't use more than about 18psi and test the seal on the master cylinder before putting fluid in the bottle by pressuring up empty...
    Its easy to use but worth getting a mate to help keep an eye on the fluid level else you may need to cycle the ABS pump too...
    Start from the rear doing the passenger side first the then drivers side... move to the front again passenger side first and drivers side then do the master cylinder nipples last... be careful with the MC nipples as they are fragile and prone to snapping
    <tuffty/>
    Apr 2012
    93
    thats great m8 thanks, i just wanted to be sure thats good advice m8, and ill go stairght to a car shop by me and buy ezzibleed kit in the morning. thanks again..
    <tuffty/>
  1. Brake bleeding - how to?
    By TeKnodriver in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th February 2012, 21:50
  2. Brake Bleeding
    By 666markyboy in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th February 2011, 11:22
  3. Brake bleeding help!
    By swatchuk in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st April 2009, 21:27
  4. Brake Bleeding
    By GSXpress in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th December 2007, 11:56
  5. Brake Bleeding
    By Pat in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th October 2007, 12:49
