AH FabricationsBadger5
    Apr 2012
    93
    bleeding brakes on s3
    hi all, i got an s3 with spongy brakes, it hade bin standing a bit, me and my m8 are going to bleed the brakes and free the capilars if there stuck, sum1 has said that i might have to blead the 2 IIRC nipples on the master cylinder, wot and where are there the 2 IIRC nipples? the brakes are proper spongy and it feel like it only braking on servo brakes, there are no abs or warning lights on the dash. thanks....
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,476
    IIRC = If I Recall Correctly...
    The 2 nipples in question are on the master cylinder and need a 7mm spanner or deep socket to undo...
    When bleeding the brakes on an S3 'DO NOT' use the pump the pedal method as this can damage the master cylinder seals... use a pressure bleeder such as the Gunsons Eezi Bleed
    One last thing, please could I direct you to this... makes your posts a little easier to read
    Use of the English language...please read!
    <tuffty/>
  1. bleeding brakes A3 1.8T
    By audi_ro in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th June 2010, 19:35
  2. Bleeding brakes!?
    By campbell in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st June 2010, 16:02
  3. Bleeding brakes
    By S3_MCD in forum General Technical / How To
    Last Post: 21st March 2007, 09:49
  4. Bleeding Brakes
    By cclarke184 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th June 2004, 20:20
  5. Bleeding Brakes A3
    By marcsnoz in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th July 2003, 09:41
