Probably a simple solution so thought I would ask the question I will probably at a later date fit the rsne but for now I would like to put my stereo in the problem I have is it is a 2001 car with the canbus (only has the 1 live wire) and when you put in an aftermarket stereo it needs to be switched off at the unit which is annoying hence putting the original back in.
However thinking about this I put a stereo in my brothers merc which did the same but you could get a lead to remedy this so it worked as oiginal and switched off
Is there a lead for the s3to switch it off or can i put a wire in to somewhere? I have the lead for the amp though I think when you put another stereo in you do need to bypass this as it is not great
