EM TuningSky Insurance
Results 1 to 13 of 13
    Mar 2011
    buy st edmunds
    65
    Forge 008 boost mystery
    Fresh post as last as I went or the forge 008 but now a mystery issue
    Right now iam really confused. Yesterday I fitted a forge tip the 008 a big green cotton cone filter and a heat shield. Only did a couple short journeys but. At seemed to run nicer and smoother and went very well boost gauge was showing 19 psi at full chat. After presuming it must be mapped today after a little research on here decided I needed to swap the green spring the 008 came fitted with for the yellow one. Went for a test run and now the boost gauge is only showing 15 psi at full throttle and it doesn't have the mental surge it had before when the pedal is on the metal?? :s
    beachbuggy's Avatar
    Surrey
    1,727
    Is the spring fitted correctly? Sure it's not leaking boost? If you log you'll see requested v actual to see if you're loosing boost.
    Mar 2011
    buy st edmunds
    65
    I don't have the equipment to do data logging if that's what you mean?
    And I can't see how the spring could be incorrectly fitted was just 3 grub screws swap spring tighten back up could do it blindfolded with one hand lol. Seems to drive well just doesn't have the crazy surge it did before but to be honest that felt like was overboosting :s stil not 100% if it's mapped or what
    Benjiman46's Avatar
    R-Tech Terrorist
    Feb 2012
    Worksop
    547
    Hi mate,
    For a start, the green spring in the kit is useless. Even for a standard S3. So throw it away lol if the yellow spring isn't working properly, take it, and the piston out put some red rubber grease on the piston and use the thinnest shim, to make the yellow spring slightly stronger, then check all your hoses and connections for tightness and just check you haven't split any vacuum hoses or anything daft. It sounds silly but it could just be a massive coincidence. Hope you sort it.
    Ben
    1.8 litre porsche eater!
    R-Tech Terrorist Squad - 265bhp & 275lbft
    Mar 2011
    buy st edmunds
    65
    ok il take a look and try that thanks bud
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by Benjiman46 View Post
    Lets just clear the above up.... To say that the green spring is rubbish for a standard S3 just isn't accurate.
    Green spring is fine on most S3s and won't cause issues. It's quite a weak spring but is definitely fine for standard boost levels.
    This is how the springs break down:
    Green - 5-15 PSI
    Yellow - 15-23 PSI
    Blue - 23-30 PSI
    Red - 30 + PSI
    So, based on this - direct from the Forge website - Yellow is the colour for most Stage 1 and above S3s. Green will work fine on a stock S3 and a mapped one as well. My stage 1 REVO was run with a green.
    I currently use a 007P with Yellow running 1.9 Bar - no problems here.
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
    DJ_Troopa's Avatar
    Back in a turbo!
    Oct 2008
    West London
    1,735
    Visit DJ_Troopa's Instagram Channel
    It should be fine with the yellow spring and that's it. Nothing else to do with it tbh. I had the Forge 007p and changed it from green to yellow spring, ran perfectly peaking at 22.7psi and 270bhp. Check your hoses have been put back on properly and properly tightened, even having a slightly loose jubilee clip can affect it.
    Inferi Black Cupra K1
    vrbob's Avatar
    Jun 2007
    Southampton
    2,284
    Do you have to buy the yellow spring? as i would like to change my green to a yellow in my 007p
    Mods : Badger 5 Stg 2 Custom Map, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
    May 2010
    Bedford
    2,877
    Second time in asmany days
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,067
    Quote Originally Posted by DJ_Troopa View Post
    22.7psi sounds suspiciously accurate to me, suggesting you've read that off a liquid guage, in which case it sounds suspiciously identical to the max reading the map sensor can see, which would suggest you were probably boosting higher than that and the sensor was just clamping at 22.7!
    AARON77's Avatar
    Nov 2007
    kingston sw london
    1,314
    Love you prawn
    Thats exactl what my liquid says
    didnt know that
    Comrades of Vag find us on Facebook
    https://www.facebook.com/comradesof.vag?ref=hl
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,067
    I think the map sensor can read 2550mb, which minus 1000mb atmospheric pressure is 22.785 psi
    AARON77's Avatar
    Nov 2007
    kingston sw london
    1,314
    Stato lol
  1. Forge 007P VS 008.
    By Dani_B19 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th February 2012, 23:17
  2. Forge 008 dv - anyone fitted/benefit?
    By Jimgrim77 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th December 2011, 11:14
  3. Forge motorsport boost hoses
    By Cribbon in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 9th October 2011, 22:19
  4. Forge Alloy Boost Hard Pipe
    By DJ_Troopa in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd November 2010, 15:24
  5. Forge UNOS Boost Controller
    By tompearson in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th April 2010, 20:23
