EM TuningChris Nott
Results 1 to 7 of 7
    Mar 2012
    11
    Can anyone tell me what this part is?
    Can anyone tell me what this part of the coolent system is so I can source the gasket/oring to fix the coolent leak, its the housing that is bolted to the engine with 2 10mm bolts and has a sensor within it
    Car is an A3 8L 1.8 non turbo 1998 Sreg
    I thought it was the themostat housing but i think that may be near the dipstick
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    Coolant temp sensor is there on my s3. Situated in a plastic elbow...which is also leaking coolant on to gearbox
    MODS - Custom Code phase 1, 007p DV, various powerflex bushes, EBC grooved and drilled - red stuff pads, N249 deletion. Badger5 V2 80mm TIP. Scorpion backbox + custom centre section, LCR front splitter, Jetex Fr-08001, R32 rear ARB, Forged IE rifle drilled rods, 20mm rear & 15mm front spacers.
    TO DO - Coilovers, adjustable tie arms, DP/mani/decat, FMIC and new remap
    Mar 2012
    11
    thats it looks like it tees off to the heater matrix
    Just hasd it in bits only to realise i have the wrong gasket
    shame its half hour drive to my nearest audi
    Benjiman46's Avatar
    R-Tech Terrorist
    Feb 2012
    Worksop
    547
    Quote Originally Posted by S3featesV9 View Post
    +1
    Mines the same and that's what it is
    Ben
    1.8 litre porsche eater!
    R-Tech Terrorist Squad - 265bhp & 275lbft
    Mar 2012
    11
    Anyone know the part number for the oring? I think the GSF part number is 179VG0310 but cant be sure
    Think this is going to be another trip to Audi
    Feb 2011
    Somerset
    238
    Try a vw dealer if they are closer, normally cheaper too.
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,040
    Admittedly for a s3 but got mine from Gsf this week and was £5.90 +vat for the housing and o ring (there housing usually get brittle and brake up) where as audi wanted near double that
    Power & Torque 335bhp 285ftlb
    0-60 4.64 1/4 mile 13.02
    My GTX3071r Build Thread
    http://www.audi-sport.net/vb/a3-s3-f...ld-thread.html
  1. Part or Part code needed for Reverse switch connector?
    By reptor245 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th October 2011, 16:30
  2. Part Number, or part from a breaker needed
    By Arrkon in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th April 2011, 19:39
  3. Part luck & Part skill??
    By ScottD3 in forum You Tube Links
    Last Post: 25th December 2010, 16:28
  4. HELP naming a Part? + part number
    By shaz A3 Tdi in forum Diesel forum
    Last Post: 9th December 2009, 00:10
  5. Part number and place to buy , this S3 part?
    By s8n in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th March 2004, 01:49
