EM TuningChris Nott
Results 1 to 19 of 19
    Apr 2012
    london nw10
    s3 8l facelift driving me crazy! ABS and ESP lights
    Hello and i would really appreciate some help with this problem!
    when i got my s3 the abs light and the esp were both lit up.
    fault code points to longditudinal sensor.
    ok, so here it is, i have changed the londitudinal sensor and the lateral sensor and the abs module, have had the wiring checked, the basic settings reset and reset and all manor of diagnostics, i have got not a clue what to do next other than get rid of the car.
    The only thing i will say is, if anyone has any ideas or wants to take a look at the car for me it would be most appreciated. or if anyone can point me in the direction of a good abs specialist in the london area.
    thanks very much
    car is a 2001 s3 facelift.
    thegoal007's Avatar
    Another S3 owner....
    Apr 2008
    surrey
    729
    doesn't the haldex controller have a part to play ?
    02 plate - 2002 - 225bhp - S3 - Ming Blue - completely standard - nuff said, OK there's a centre armrest, sunroof, BOSE speakers & black leather recaros, oh and the non OE chrome pack !
    Nov 2011
    Sturminster Newton
    190
    it was the wheel speed sensor on mine that gave me the same problems this is easily checked with vag com or at a garage with vag com as you can select the module and it should come up with individual wheel speeds as you spin each wheel by hand. The cable was at fault on mine so just one more thing to look at.
    A3 1.8TQS Minge blue
    Mods: AP coilovers, Strut Brace, Merc wheels, S3 brakes, hopefully going BT soon
    Apr 2012
    london nw10
    the fault code i cant get rid of is 01279 longitudinal acceleration sender g251 electrical fault in current circuit.
    another one comes an goes 01279 longitudinal acceleration sender g251 sporadic implausible signal.
    A
    thegoal007's Avatar
    Apr 2008
    surrey
    729
    just so that we understand it corectly, you were getting all these errors before and after you replaced the londitudinal sensor and the lateral sensor and the abs module.
    very strange. I presume these were new parts ?
    the wheel speed sensor checks are also ones to try as advised above because although strictly speaking none of them are showing as faulty on vagcom - they may just be giving you an incorrect reading which may be causing your issues.
    NB. That abs module is like super expensive, a £1000 part (new).
    Feb 2012
    1,104
    I had this exact issue a few years ago and nothing would clear it then one day i was playing with the longitudinal sensor while watching the value readings on vagcom and it kept going from 0-20 approx in the blink of an eye. I pushed the sensor a little harder and it wasnt plugged in crrectly. I know that sounds daft but i never touched it before it starting playing up so who knows why it happened but try the same if you have vagcom. You can get a much better idea if the car is static and its values change. And the guys are right wheel speed sensors are somehow linked so can through dodgy fault codes. You really need to study vagcom values not keep buying bits. It took 4 garages 4 new diferent sorts of sensor and £600 for me to fix it after picking the car up from the last garage that failed to fix it. Keep posting as much info as pos!! daz
    S3_Olly's Avatar
    Full Throttle
    Jul 2011
    Aston, Sheffield
    153
    Hi mate im having the same issues at the minute and apparently mine is a G60 relay 90 or something so just waiting for the garage to get hold of that.
    i have just bought off ebay the the longitudinal and latitudinal sensors off ebay just in case, but cant find the one behind the glovebox if you happen to know where that is lol. they dont make things easy to get to do they but yes let me know how you get on as it sounds exactly the same as mine.
    cheers Olly
    Feb 2012
    1,104
    Hi olly. I spent ages searching for this too. If my memory serves me correct and hopefully it does. The pre facelift is behind the glovebox the facelift is under the steering colomn. If its the glove box option its no hidden to well so should be obvious. You taking it fully out mate? Daz by the way i fixed mine years ago through searchin on here. There was a good guide. Ill try to find it for you!!
    S3_Olly's Avatar
    Full Throttle
    Jul 2011
    Aston, Sheffield
    153
    Hi DAZ, mine is the audi s3 8l Facelift but there is that many people saying where they are that i just bought a **** load of sensors and thought id try my luck at finding them lol but to no joy at the minute.
    i belive that the tech that had a look at mine a while ago said it was a G60 Relay 90 or something but not 100% sure if thats right, i Could live with it but i dont think the MOT new regs would agree with that plus its just more annoying than anything.
    if you have some sort of diagram or know where these are that would be a great help.
    here are the quick links just to show you the ones that i have got .....
    2001 AUDI VW SEAT 1.8T ACCELERATOR SENSOR VAG 1J0907651A | eBay
    AUDI VW PASSAT MK6 BOSCH YAW ESP TURN ACCELRATOR SENSOR 8E0 907 637 A 8E0907637A | eBay
    VW SEAT SKODA AUDI GOLF MK4 YAW RATE SENSOR 1J0 907 657B / 1J2 907 637B | eBay
    Cheers Olly
    Feb 2012
    1,104
    What codes are you getting up?
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    on my car, longitudinal behind glovebox, lateral under steering column. unplugging one or the other and checking with VCDS will confirm which is which. i first thought, and many people told me, it was the other way round, until i replaced the steering column one and nothing happened, then i worked it out.
    i literally plugged mine in and the fault never appeared again.
    p.s. i have a part number if needed, and a price which is many many monies. it think the two sensors are identical, just mounted differently so they read in the directions they do in VCDS.
    Feb 2012
    1,104
    I think your right mate. It was such a long time ago im struggling to remember. But one of the sensors i thought changed position between pre and facelift. I may be wrong. But it was such a strezsful issue i feel for these guys. The sensors are the same im sure. Vagcom readings are crucial to solving this imo.
    Apr 2012
    london nw10
    ok, here goes, the controller pn, 8n0-907-379-e Replaced at a cost of £1125 inc vat. longitudinal sensor changed cost £410, lateral sensor changed £144. Auto electrician £75 to check wiring ............. STILL THE SAME CODE
    Are there any ABS brake SPECIALISTS around?
    Apr 2012
    london nw10
    Sorry, forgot to say. the facelift sensors are on a bracket attached to the steering column. the top one is longitudinal and the lower one is the lateral sensor.
    when i check my values on vag-com, the longitudinal os -7.68 after basic settings which is wrong value. it should be -1.5 to +1.5 but it wont go there no matter what i try. Changing the controller did make some difference though, before the car was always in 2wd but now its 4wd all the time, so on a tight turn the wheels seem to grip a lot too much.
    Feb 2012
    1,104
    What happens when you play with the wires. Try moving them around to see if its a break. Dont go too rough and break it. Does it stay at that value or fluctuate. just play around while keeping an eye on it. Check the connections are clean etc. Have you check wheel speed sensor values
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    The longitudinal is behind the glove box on the facelift s3 - you can (just) get to it by removing he side panel but taking the glove box off is a 5 min job and makes access a lot easier.
    Both the sensors (long and lat) are the same part number so I'd start by swapping them over and rescanning the car.
    The lateral is on the steering column together with another sensor held in place with a gold colour bracket.
    Im not local (Epsom) but happy to help if you get stuck
    Mike
    S3 AMK
    Bilstein B8's & Eibach Springs, Neuspeed ARB's (22mm front & 19mm rear).
    Badger 5's Machined Discs with DS2500 pads & HEL braided lines.
    Chlippo's Avatar
    Apr 2010
    Canada/USA/Lebanon
    666
    I am facing a similar problem,
    -error 01279 Longitudinal acceleration sensor (G251) Implausible signal
    -error 00285 ABS Wheel speed sensor: Front Right (G45)
    Then again
    -error 00285 ABS Wheel speed sensor: Front Right (G45) Signal outside tolerance.
    Any ideas?
    And also what are the part numbers i need here (TT or S3 since no S3 here in Canada/USA)
    I found these two for the longitudinal sensor 1j1907638b and 1j0907651a...The price isnt the same thou...
    Audi S3 AMK
    Relentless-Manifold, Relentless-3" downpipe decat, Forge 007 DV, autobahn88 TIP, K&N Panel filter, EBC yellowstuff brake pads, R32 ARB, Custom column dual gauge pod...waiting for a remap!
    For help/info/pricing on xs manifold and downpipe pm me (not affiliated, nor a reseller trader, just an enthusiast!)
    Nov 2011
    138
    hey guys.
    having this issue too. however the fault that came up was the brake light sensor switch. So we replaced that with a brand new (genuine) one and the lights came on again on the way home. Very confused as this was the only fault that came up.
    It came up in 2 places on the ECU (can't remember where) and alex at Storm developments fitted the new sensor then cleared the faults.
    any ideas?
    James
    Apr 2013
    JHB, South Africa
    168
    Im having the same problem with my car at the moment. 2002 8L S3 AMK. I also see that the ESP light flashed every now and then and kills the power. Any ideas?
  1. ABS and ESP lights on
    By Metro in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th March 2012, 20:41
  2. ABS, ESP, Steering Lights - Lights galore!
    By Farhan in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th February 2012, 19:45
  3. A4 S4 B5 - ABS & ESP lights are on since driving and braking over ice??
    By S4DemonGreek in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th February 2010, 19:55
  4. ABS/ESP LIGHTS ON
    By mike-turbo in forum VCDS (formerly VAG-COM) forum
    Last Post: 9th February 2010, 21:42
  5. ABS ESP Lights on
    By downie in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th May 2007, 20:13
Tags for this Thread
