Volks AutosAH Fabrications
Results 1 to 10 of 10
    UK
    289
    EIP Haldex Controller
    Right..have had this fitted for a couple of weeks now, so can post thoughts.
    Its a subtle mod, under normal driving you wouldnt notice anything different and you need to be pushing things to notice the subtle changes to the cars handling. Now oversteer can occur on roundabouts (if provoked, although cant say 100% how much of this is down to the Neuspeed ARBs) and can 'feel' power from the rear wheels if powering off a roundabout on to a straight - and if you keep your foot in around roundabouts you can feel the back end pushing the nose back in line.
    My cars handling is already fully modified (suspension/springs/roll bars/tie bars etc) but this I think really does eliminate understeer - car handles really really great at the moment.
    Need to do a track day to fully verify but so far I am happy
    Dunc
    JaminBen's Avatar
    Jan 2005
    France (ronRonrRRron)
    532
    Re: EIP Haldex Controller
    Having driven a standard S3 and an R32, which both have the earlier Haldex, and then driven my 8p Q, I can say Dunc S3 is right on the money.
    The newer Haldex, with its pre-engaging capabilities and more complex electronics, really does a lot to reduce understeer. You still have to set up the car properly at the entrance of a turn to get lift-off oversteer, but once you're back on the go-fast pedal the Haldex just latches on, and you're in a very subtle 4wheel drift.
    Another big plus of the newer-gen Haldex coupling units is the pre-engagement. When doing a standing start with the wheels turned, the rear drive is engaged before slip ever has a chance to occur.
    clcollins's Avatar
    Mar 2004
    Lancashire
    276
    So how much does this do-hicy cost then, and is it a 'plug & play' device or do you need to fork out to have it fitted and set-up?
    Dec 2004
    cornwall
    229
    i wonder if audi fitted this newer haldex ecu instead of the old when they replaced it a few weeks ago? il go and find a wet roudabout to work it out!
    UK
    289
    Ian, Audi wouldnt fit it - its not an Audi part
    information here:
    http://www.eiptuning.com/eip/haldex.html
    I believe there is or was an AMD group buy at 499 + vat fitted
    Dunc
    AndybS3's Avatar
    Jun 2003
    Central Scotland
    233
    Pretty easy to fit but a bit of a squeeze to get to, two allen bolts and a multiplug job done
    Nov 2004
    Hosrham, West Sussex
    390
    [ QUOTE ]
    [/ QUOTE ]
    They will of fitted a standard one, make sure the roundabout is empty before you try [img]/ubbthreads/images/graemlins/wink.gif[/img]
    If anyone is interested I will be selling my performance haldex unit in the next few days (someone has 1st refusal on it right now) for 475 ... 135 cheaper than the group buy price.
    Cheers,
    Adam
    Jan 2005
    60
    [ QUOTE ]
    [/ QUOTE ]
    Why are you selling?
    Nov 2004
    390
    [ QUOTE ]
    [ QUOTE ]
    [/ QUOTE ]
    [/ QUOTE ]
    Because I'm selling my car and it's worth a lot more unfitted.
    ..sold now anyways.
    Cheers,
    Adam
    Jan 2005
    60
    I see then; was just interessted in knowing if you didn't like it :-)
    Thanks.
