Results 1 to 11 of 11
Thread: Lack of Boost.
    Nick090884's Avatar
    Mar 2012
    rochester
    195
    Unhappy Lack of Boost.
    Hi guys wondering if you could help ?
    ive done a scan of my a3 1.8t aum and had a few faults.
    mostly misfire , ive read a few post and found out my coil packs were under a recall. had them done the other day and it seems to be better.
    the main problem is the malfunction of my N249 valve. when driving i get a fairly loud hissing nosie followed by a noise sounding like a dump valve, so i've checked to see if the donnut that last had the car had put one on and its the standard oem diverter valve top right corner under the engine cover (If im looking in the right place) im a complete newbie to a turbo and dont know where to even start.
    Any help would be greatly appreciated,
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,025
    Post up the fualt codes mate... codes will help work out whats going on..
    This will also help...
    Category:Fault Codes - Ross-Tech Wiki
    By malfunction of the N249 I will assume you got a 'mechanical failure' code? has the N249 been bypassed?
    Any other details such as if the engines remapped, other mods etc will help but get the codes up from the scan
    <tuffty/>
    Nick090884's Avatar
    Mar 2012
    rochester
    195
    Hi there tuffty, i will post the fault code asap. its a standard aum , and havent had a N249 bypass. yes the fault i get in vcds is 'mechanical failure' . i will scan with vcds later and post . ive only have the vdcs lite ATM.
    Many thanks
    Nick
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,025
    If you haven't done the bypass and you are getting that fault with a std DV then I would imagine the DV is the problem... you should be getting a choo, choo, choo type noise letting off part throttle if the diaphragm has gone... OEM ones are cheap... or get a 007p/008 from Forge
    <tuffty/>
    Nick090884's Avatar
    Mar 2012
    rochester
    195
    That is excatly the noise id say im getting. as im climbing speed under full throttle its like its leaking air from the same part/ area before i get the choo choo choo noise.
    cool thanks again <tuffty/> i'll repost after i get my new DV.
    Nick090884's Avatar
    Mar 2012
    rochester
    195
    Hi there ive been out and scanned the car it came up with a few alarm triggers that i think are old, a fault on the left hand auto level sensor which im not worried about at the moment. and the address 1 for the engine is :
    VCDS-Lite Version: Release 1.0
    Thursday, 12 April 2012, 14:56:50:0
    Chassis Type: 8L - Audi A3/S3
    Scan: 01,02,03,08,15,16,17,22,35,37,45,55,56,57,75,76
    Address 01: Engine Labels: 06A-906-032-AUM.LBL
    Controller: 06A 906 032 DK
    Component: 1.8L R4/5VT 0001
    Coding: 11500
    Shop #: WSC 06435
    WAUZZZ8LZ1A005994 AUZ7Z0Y1459193
    2 Faults Found:
    17608 - Boost Pressure Control Valve (N249): Mechanical Malfunction
    P1200 - 35-00 - -
    17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
    P1297 - 35-00 - -
    Readiness: 0000 0000
    I think <tuffty/> your right. i take it i should change the DV first before doing anything else??? O yeah there no Engine managment on at all hasnt been since ive owned the car. Cheers
    Nick090884's Avatar
    Mar 2012
    rochester
    195
    Hi ya Peep's.
    ive fitted the new DV today got hold of one from a vrs, the loud hissing noise has now gone and the DV is silent rather than sounding like the choo choo choo that was said by <tuffty/>. i still get a small amount of nosie as the turbo spools up, is this right and just the turbo making noise. Also i would like to know if i have a ko3s or ko3 turbo. the power since ive changed the dv doesnt seem any different, would i notice a change or not ??? i know a DV makes no proformance diffrence but thought as the oem one was damage it might. thanks guys.
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    Aum has the k03s standard unless it's been replaced at some point. I've got a noticeable spool and dump sound since I put a 007p, silicone tip and pipercross panel filter on. Although it wasn't exactly silent in standard form like I've been lead to believe.
    As for the faults im not too sure sorry. Check the ross-tech wiki like tuffty suggested
    Audi A3 1.8t AUM
    Forge 007p, Pipercross Panel Filter, Eibach Prokit 35mm drop, EBC Green Stuff Pads
    Groved Disks, HEL Braided Brake Lines with Dot 5.1 fluid.
    Creation Motorsport Silicone TIP,
    N75 hoses, DV Hose & 10mm Rear Wheel Spacers
    Powerflex Rear Beam Bushes & Diesel Dog Bone Bush
    8k HID Kit, 8k LED Side Lights, 8k Number Plate LED
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,025
    Has the car been mapped? I don't think you would notice the drop in performance if its std...
    <tuffty/>
    Nick090884's Avatar
    Mar 2012
    rochester
    195
    <tuffty/>
    The car is standard, been out for a hour or two it feels nice to drive think its the same just alot quieter im a happy man
    nice one <tuffty/> for the advice in the first few post's , and nice one Metro for the details on the turbo. Cambelt belt change and a good service then Modding Time !!!!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,025
    Good news and you are welcome...
    <tuffty/>
  1. Lack of boost pressure
    By Krymej in forum General Technical / How To
    Last Post: 20th July 2011, 20:41
  2. lack of boost?
    By finny_quattro in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th June 2010, 16:10
  3. Intermittent Lack of Boost
    By mastas3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd November 2009, 07:58
  4. Lack of power-98 tdi110SE-just fixed blown boost hose.
    By Prawn in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th March 2007, 15:51
  5. Lack of boost.... :~(
    By S4_dan in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th May 2006, 23:57
