Sky InsuranceAH Fabrications
Results 1 to 11 of 11
    Feb 2012
    70
    G200 Lateral acceleration sensor replaced, still got ESP light. Reset needed?
    I've read that lot's of people haven't had to have there's reset with Vagcom and simply changed the sensors and the light went off.
    Anyone been in this situation?
    If it does need to be reset I'm guessing I will need the proper version of Vagcom to do it? A friends garage have the Bosch laptop will that do the same thing? We used it to find the problem but I'm unsure if it can reset the sensor. Plus I can't get of hold of him to ask.
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,487
    Where are you located?
    Feb 2012
    70
    Exeter
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,487
    Ok, here is a link for users on here who have VCDS cables. Click on the blue baloons of those in your area and send them a pm and ask them if they will do a scan for you. Its worth a try. Sorry i cant be more use than that.
    Audi-Sport.net VCDS Users - Google Maps
    Hope it helps.
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,787
    Is it actually sitting flat? When I had to replace mine, I had the same issue and then realised the actual mount was bent. Presumably when the clutch pedal was fixed. Something to check.
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
    Feb 2012
    70
    Quote Originally Posted by Sam_ View Post
    When you say flat.. How would I check this? If I was looking at it head on should it look completely flat?
    Right, going to dig out my spirit level.
    I'l give this a look Sam, I did come across your old thread earlier.
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,787
    The sensor should be flat when it's in the mounting. Mine was a little pissed. Should be pics in my thread near the start.
    Feb 2012
    70
    I'm guessing the top right part should be straight rather than the angle it's at now?
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,787
    Yeah, exactly that. Somehow mine got bent and it was confusing the sensor...
    Feb 2012
    70
    That would make sense. The sensor can only go in one way in it's little bracket so that can't be cause for concern.
    I'l get the bracket it off tomorrow and see if it's to blame.
    thegoal007's Avatar
    Another S3 owner....
    Apr 2008
    surrey
    729
    are you guessing at replacing the part or did it throw up an error ?
    02 plate - 2002 - 225bhp - S3 - Ming Blue - completely standard - nuff said, OK there's a centre armrest, sunroof, BOSE speakers & black leather recaros, oh and the non OE chrome pack !
  1. Replies: 4
    Last Post: 24th March 2012, 18:24
  2. Lateral Acceleration Sensor
    By davyb69 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th November 2008, 17:58
  3. Lateral Acceleration Sensor
    By MikeA3 in forum Parts Requests
    Last Post: 4th November 2008, 15:57
  4. 01413 Lateral Acceleration Sensor G200
    By Badgeronimous in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th December 2007, 15:50
  5. Lateral acceleration sensor
    By MarcA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd March 2006, 11:46
