Badger5JMB Retrofits
Results 1 to 9 of 9
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,390
    Boost problem after fitting tfsi coil packs??
    Could be coincidental but, I have fitted a set of tfsi coil packs today and taking it for a test run.
    The car seems to be pulling better and running better but when it comes onto boost it seems to hold back then take off.
    I have a forge 007p dv with the 1st stage uprated spring (yellow I think)
    My car has a stage 1 revo map.
    I am thinking the old coils were on the way out and holding the car back a bit.
    I have run a scan and not getting any faults.
    Can anyone advice if you think it is the dv holding the boost back / sticking or could it be the coil packs ( which seems strange as it feels so much stronger)
    Thanks all.
    2001 S3 (AMK)
    AEM WMI Kit, Black Silicone Hoses, Badger5 TIP with Cone Filter, AH Fabrications FMIC, Relentless Manifold Downpipe & Sport Cat, Miltek Cat Back Exhaust, VAG Aero Wipers, Forge FMDV008 Re-Circ, Revo Stage 2 Remap with SPS+ Tweaks, 2.0 TFSI Coil Pack Mod, B&M Short Shift, RNS-D Retrofit, Brembo & B5 2 Piece Rotor Conversion
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,639
    Ive just ordered some from awesome GTI. Have you put your original coils back on to see if it makes any difference? Also are you using adaptors by any chance?
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,390
    Not using any adaptors.
    I haven't tried putting the old coil packs on yet as its a bit late tonight to try it.
    I'm thinking it is a dv problem or possibly n75 as it is running and pulling better than before. Just the hesitation before it kicks in.
    2001 S3 (AMK)
    ShaunS3's Avatar
    Yorkshire & Humber Rep.
    Mar 2012
    West Yorkshire
    882
    Sorry...abit off topic but how much are the tfsi coils and how much difference do they actually make?
    What are the benefits/advantages over standard coils?
    Chugger
    North Devon
    2,716
    Only real advantage is they somehow make the 1.8t smoother on part throttle. No power gains have been proved really, at least when bill and tufty tested them there wasn't. They will also help cars running high boost levels, which doesnt include any running a k04 lol.
    There is a couple fairly decent threads on here about the tfsi coils
    57 A3 2.0 TDI Sportback (140)
    Chugger
    North Devon
    2,716
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,390
    Have a look around for them I get four genuine brand new ones from eBay.
    Like it has been said above, I don't think there is any performance gain but better running.
    I think my old ones were shot, I had one fail a few weeks ago due to oil ingress from a leaking rocker cover gasket.
    I only replaced that one at the time as planned on getting these and now try have been fitted I can definitely feel the car running an pulling better.
    Only thing I have is this hesitation before it takes off on boost. But I think this is due to something else.
    I am hoping someone can throw me some advice on her
    Thanks.
    2001 S3 (AMK)
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,639
    What gaps are your plugs running?
    RIP S3dave
    May 2004
    nr Glos
    7,177
    no performance gains in power/torque from the tests we did on 2 types and larger gaps..
    BUT in real world driving tuffty reports slightly improved mpg and smoother running
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
  1. 2.0 TFSI Coil Packs on a 1.8T
    By Westy in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th June 2014, 12:53
  2. Replies: 12
    Last Post: 21st June 2012, 14:21
  3. Cheaper coil packs and better running (MarkIV TFSI coil pack)
    By docurley in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th August 2011, 13:59
  4. Coil Packs
    By metricspaces in forum Parts Requests
    Last Post: 22nd September 2009, 21:11
  5. Coil Packs?? Help
    By Add7 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th September 2004, 21:19
