Badger5Chris Nott
Thread: Buying an S3
    Aug 2005
    UK
    19
    Buying an S3
    Hi Guys!!
    Sorry for all the questions but i would really like to know what to look out for when buying an early S3??
    Are there any common problems/faults with early S3s or S3s on the whole which i should keep an eye out for??
    Anything you could think of would be great!
    Also, what insurance group does the s3 fall under. I have read it is 16 but also read its 18 on other sites!!
    Thanks again !! [img]/ubbthreads/images/graemlins/smile.gif[/img]
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,436
    Re: Buying an S3
    Common problems off the top of my head are knackered MAF sensor(around 80 to replace) which means poor throttle response, increase fuel consumption, poor power, and uneven power delivery. Gearbox crunch changing fron 2nd to 3rd at high revs is normal, tired front track arm bushes - these require the whole track arms to be replaced - the motors on the self levelling xenons seem to be a problem. And the DIS display likes to go AWOL, where the diplay starts to fade.
    My 99 S3 (46K miles on the clock) has had a new MAF sensor and the front track arms replaced, and the DIS is failing, but Noy bothered about the DIS, so switch it off.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,436
    Re: Buying an S3
    Oh, and coilpacks are weak(like a misfire, running on 3 cylinders) for early S3's, but they should have been replaced under warranty by now!
    Aug 2005
    UK
    19
    Re: Buying an S3
    Thanks for your help jojo - much appreciated!
