JMB RetrofitsAH Fabrications
Results 1 to 24 of 24
    Alex C's Avatar
    Lizard, Cornwall
    2,603
    Crunchy up into third gear
    TBH I don't really want to ask the question because I am worried about the answer having had the gearbox pulled out just over a year ago for a broken shift fork.
    Anyway, I have noticed (today) that pretty much on each and every gear change up from 2nd into 3rd gear that the gears crunch. It doesn't do this on any of the other up-shifts and it doesn't do it on any of the down-shifts not even from 4th to 3rd either.
    If I up-shift from 2nd to 3rd abnormally slowly then there is no crunch, but on a normal shift it crunches.
    I have two potential causes in my head: syncro-mesh or dogbone bush?
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    I have the EXACT same thing.
    My dad (mechanic) says its 100% synchro.
    If I'm giving it the beans, shifting above 5k, I have to shift really slowly into third.
    Alex C's Avatar
    Lizard, Cornwall
    2,603
    **** i am officially depressed
    Alex S3 AMK
    Oct 2011
    760
    i had this problem, uprated dog bone fixed mine.
    cheap fix
    Alex C's Avatar
    Lizard, Cornwall
    2,603
    thanks, guess it makes sense to change that first. I fear the worst though
    Alex S3 AMK
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,575
    I had this in the earlier days, it only happens when shifting 2nd into 3rd at high rpm. Dogbone mount cured mine, I've not done it since, even out on the track!
    Alex C's Avatar
    Lizard, Cornwall
    2,603
    ooooo! the futures looking bright! OK, I'll get a new dogbone bush asap and see if it fixes the problem.Thanks for giving me hope guys
    which dogbone bush is the one every one opts for?
    this one? Red One
    Alex S3 AMK
    Jun 2011
    249
    Quote Originally Posted by Alex C View Post
    this one? Red One
    diesel?
    A3 S Line 2.0 TDI Sportback - DSG
    BOSE, cruise control, bi-xenons, MFSW, Heated seats, paddle shifts, ipod connection
    19" Speedlines | Reverse camera | Eibach Sportline Springs | MY09 LED Tails | Eibach Spacers Front 10MM Rear 12MM | Pioneer HU | Private Plate | Tints | LED numberplate | Interior Light Kit
    Alex C's Avatar
    Lizard, Cornwall
    2,603
    yeah, apparently from what i have read elsewhere. The yellow one (petrol) is too harsh
    awaiting confirmation though bud
    dog bone bush best one ?
    got it
    Alex S3 AMK
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Mine has started to do thus from 2nd to 3rd but is only at higher revs when driving it hard, but I already have uprated both the dogbone mounts underneath but I think my engine mounts are pretty shot and have got some on order so only time will tell
    Power & Torque 335bhp 285ftlb
    0-60 4.64 1/4 mile 13.02
    My GTX3071r Build Thread
    http://www.audi-sport.net/vb/a3-s3-f...ld-thread.html
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    hmmmmm, i know my dad said its synchro, but perhaps i could do with tightening my poly dog bone mount. maybe my engine mounts are shot too, i wouldnt be surprised.
    my gearbox is absolutely fine unless im giving it beans.
    hard to imagine a bush/mount having such an effect on gear changes
    Dec 2011
    Hockley Essex
    309
    i fitted the yellow dog bone bush a little while ago now and it sorted out my gear crunch and i haven't found it to harsh at all . Well worth doing ! Completely transformed my car !
    mattyboy199's Avatar
    Nov 2005
    UK
    1,689
    i had a similar issue but it only occurred when the engine was at full tempreture, anyway i knew i was due a new clutch. Got a new clutch and flywheel fitted the issue disappeared.
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    danger S3's Avatar
    Jun 2010
    Edinburgh, Scotland
    355
    Hi, sorry to dig up and oldish thread but i have this problem too.
    Although it only crunches once the gearbox has warmed up so after about 30 - 45 minutes of driving.
    I've changed the gear oil, replaced the clutch/brake fluid, bled the clutch and adjusted the gear linkages.
    I was wondering if its because the viscosity of the oil when its hot is too thin. would changing the oil to something other than the oem gear oil make a difference?
    Ali
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,575
    Quote Originally Posted by danger S3 View Post
    Ali
    Dogbone mount mate, I don't even remember the last time I crunched my gearbox since having this £20 part fitted!
    danger S3's Avatar
    Jun 2010
    Edinburgh, Scotland
    355
    sorry i forgot to add that to the list, ive added the red dogbone powerflex one and its still doing it, although it was about a year ago i added it, could it need tightened?
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,575
    Can't answer your question, but the dogbone mount only needs to be done up as tight as you can by hand with a ratchet, then there's a specific torque setting for it bolting onto the car's baulkhead.
    Alex C's Avatar
    Lizard, Cornwall
    2,603
    i fitted a dog bone mount too in the hope it would be an easy fix -- failed for me too.
    Suspect its worn synchro rings.
    I have put molyslip in the box and now double declutch and heel toe to nurse the gearbox around, its still notchy like this but doesn't crunch
    Alex S3 AMK
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,640
    I had the exact problem. Sometimes its still there even with a dogbone mount but I think my engine mounts are crap. Also my xfer box is leaking at the prop so Im short on oil too! Im getting that done so time will tell. When I got the oil changed in the gearbox before, it made it feel soo smoooooth!
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Quote Originally Posted by StaceyS3 View Post
    As an update to my previous post I ended up killing my box.... Pretty sure was the selector fork gone as only could select 3rd and 4th and was permanently in gear, even in the neutral position
    Jun 2012
    Essex
    215
    I've got this issue, from 2nd to 3rd I get a crunch every now and again. And 1st, every now and again will just pop out of gear.
    Changed oil, fitted poly dog bone mount and still have the issue.
    Pretty sure it's synchro, so just nursing the gearbox until I can afford a new box and diff, ready for ko4 conversion late next year
    danger S3's Avatar
    Jun 2010
    Edinburgh, Scotland
    355
    anyone reckon changing from the oem gear oil to something like Red Line MT-90 75W90 GL-4 Gear Oil would help with notchy gears and crunching from 2nd to 3rd when warm? or am i just clutching at straws
    colicabcadam
    red line made a huge difference to my box, ok it was not as smooth when cold (0 degree cold) , but after about a mile it was SO much easier to change gear !!!
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,788
    Going to chuck some redline in mine this weekend, along with a sump, pickup and oil change...
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
  1. S3 2nd Gear / 3rd Gear "Notchy" problems
    By NME in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd May 2011, 11:31
  2. 2nd gear 'crunchy' from cold
    By leshkin in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th February 2010, 23:01
  3. Top Gear gear
    By voorhees in forum Jokes, Games & Humour
    Last Post: 27th June 2009, 11:43
  4. No fifth gear
    By Redhot006 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th March 2008, 19:09
  5. notchy / crunchy gear change
    By technics100 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd March 2007, 15:12
