Chris NottJMB Retrofits
    s3joe's Avatar
    Mar 2012
    Liverpool
    296
    Visit s3joe's Instagram Channel
    Drivers footwell wet
    I have just been hovering my car an found my footwell was wet under the clutch pedal any ideas please.
    Danman1's Avatar
    Thorough noob
    Sep 2011
    West Midlands
    338
    Scuttle panel under window screen leaking. Common I believe. Bead of silicon across it may fix it?
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    Yep, the scuttle panel sealing and I also bet the drain holes in the upper front wing are blocked so you've got a puddle of water sloshing around next to the ECU. VAG group cars have some great design faults!
    Recommend you take the wiper arms off, remove the scuttle completely and then clear out all the detritus from either side and make sure the drain holes run free. I now do this every couple of years on S3 and Cordy as part of routine maintenance.
    Jason
    2001 Nogaro S3 (daily driver)
    1958 replica Porsche 356 Speedster (summer posing)
    1997 Seat Cordoba SX 16v (track day toy) replacing (t)rusty 1994 Seat Ibiza GTi RIP
    s3joe's Avatar
    Mar 2012
    Liverpool
    296
    Ok I'll have a look at this thanks guys.
    S3 TAM's Avatar
    Pocket now empty
    Oct 2009
    London & Hertfordshire
    621
    Could be clutch master cylinder leaking.check behind the pedal.
    Revo Stage 2 with all the Gear
    BHP = 274 / Torque = 293
    s3joe's Avatar
    Mar 2012
    Liverpool
    296
    look behind it for what fluid or water getting in
  1. WET PASSENGER FOOTWELL
    By wickyianr1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th September 2011, 18:41
  2. wet drivers footwell
    Last Post: 25th January 2011, 07:33
  3. Replies: 10
    Last Post: 27th October 2010, 20:44
  4. Aaaaargh wet footwell!
    By 88A4v6 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th October 2010, 18:46
  5. Steam coming through the vents and wet passenger footwell...HELP!!
    By Higgsy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd June 2010, 17:15
