Sky InsuranceJMB Retrofits
    Feb 2004
    Middlesex
    79
    Mirror fitting/replacement on S3
    Anyone fitted or changed their mirrors on an S3, i plan on fitting a pair of RS4 mirrors tomorrow.
    I have had a quick look and at a guess i have to take the door cards off to then take off what appears to be a plastic cap that covers the bolts to be able to then remove the hole mirror assembly.
    If anyones done it or got any advice it would help me out, before i go pulling my S3 interior apart.
    Chris
    Nov 2003
    Milton Keynes
    54
    Re: Mirror fitting/replacement on S3
    Don't take the doorcards off!!!!!!!
    Fitting them is very easy.
    Just do the following:
    1. Adjust mirror so the bottom end sticks out (ie the glass is pointing skywards)
    2. Using your fingers, pull the glass GENTLY away from its holder.
    3. Disconnect the wires - mark which one goes where!!
    4. Under the mirror housing, you'll find 2 screws - remove these.
    5. You'll also find 2 or 3 more screws on the inner of the housing that attach the motor etc to the housing - remove these. They may be Torx screws so make sure you've got a set of Torx screwdivers handy!
    6. Lift the housing up, starting at the section closest to the door. Takes a while, but you'll note that some there are also some plastic connectors that have to pull away from the housing.
    7. Refitting is reverse of the above!
    Feb 2004
    Middlesex
    79
    Cool, thanks for advice.
    i'll check it out in the morning.
    Chris
    Feb 2004
    Middlesex
    79
    Ok sorted, was easy as.... only took about half hour.
    have a look.
    Sep 2004
    Glasgow
    919
    looking very very nice [img]/ubbthreads/images/graemlins/ok.gif[/img]
    Nov 2003
    Milton Keynes
    54
    Told ya it was easy!!!
