Chris NottMonster Motorsport
    actualeddie's Avatar
    Feb 2012
    Waltham Abbey, Essex
    211
    Hose Behind Engine
    Hey guys,
    That Hose behind the engine, red one that I believe goes straight into the turbo; Well that's finally gone on my S3 (no boost at all now) Luckily I have a new Forge one coming tomorrow!
    Is it an easy switch around? There may already be a tutorial, but i'm not sure what to search, Turbo hose?
    Thought I'd better post a photo of the hose in question.
    Cheers again for any help,
    Eddie
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    741
    Have got one of these myself to fit this weekend too, looks easy ennought but then they always do and sometimes canbe apain. Looing at your photo I see you have your DV venting to atmosphere, that wont be doing much good for your performance as the MAF wont be seeing all the air it should, a Forge 007P considered the best DV option.
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
    Feb 2012
    211
    Funnily enough someone suggested that on another post I put up, when I bought the car it came with. Will change it when I can, should be a simple switch on that too right? They usually come with a cap but I didnt get it handed on to me
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Turbo pipe is very easy to do, you may find it even easier if you remove the strutt brace...
    Feb 2012
    211
    Ah good idea will do. Ill have to try find somewhere that sells decent clips too.
  1. Engine bay silicon hose kit
    By riggssuzuki in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 20th February 2012, 17:29
  2. Replies: 2
    Last Post: 1st December 2011, 23:31
  3. Removing metal engine bay hose clips
    By Darren4 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th October 2011, 12:27
  4. what hose is it????
    By dplovin in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th September 2011, 13:54
  5. Which hose is this?
    By finesse in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd September 2010, 17:48
