EM TuningSky Insurance
Results 1 to 16 of 16
    fitzdog88's Avatar
    Apr 2012
    leeds
    59
    Angry Fault code help needed 2000 S3
    two days ago my car went into limp mode just been to a garage with vag com and got the following codes
    17863 exaust gas temp sensor 1 (g235) implausible signal
    17608 boost pressure control valve (n249) mecanical malfunction (just done the delete and pluged the sensor back in )
    17705 pressure droped between turbo and throttle valve ( previous owner had fitted a dump valve replaced this this morning with new 007p )
    17956 boost pressure regulation valve (n75) open circuit
    17938 camshaft timing adjustment short to ground intermittent
    17697 boost pressure control valve (n249) short to ground intermittent
    16396 bank 1 35 10 advanced set point not reached(over retarded) intermittent rediness 0000 0001
    the guy at the garage didnt want to erase them as he thought the car wount start after so any help with possable reasons for the faults will be much apreciated guys
    also i have not been able 2 wipe the ecu after n249 delete and 007p fitting would this explain some faults
    p,s my friend has a mac code reader would this clear them
    thanks matt
    Aug 2010
    1,540
    you need those clearing to sort out whats old and whats causing the fault/lack of power.
    the n75 fault. any broken wires to it?
    exhaust gas temp will be causing lack of power if its a current fault (not an old one) but without them clearing.........
    Markeyboy's Avatar
    Fan of the R-Tech!
    Aug 2011
    Thurrock, Essex
    281
    clearing the codes wont cause the car not to start, it just clears the fault code register.
    as said above, you need to find out what the current faults are and then go from there, mine had a load of really obscure codes when i first scanned it, reset them and ran the car for a coupple of days and took it from there,
    pressure drop between dv and throttle valve has been a real battle for me in the past, dam vac leaks
    1.8T SPORT AUM
    18" TTRS wheels, de-badged grill, tints, TIP, forge 007P, toyo sports oil catch can,
    3" downpipe + decat, Toyosports FMIC, 10mm lowering cups, N249 bypass
    S3 Front Brake Setup, R-Tech stage 1.5 custom remap 218BHP@229FT/LB
    Progression Thread
    http://www.audi-sport.net/vb/a3-s3-f...8t-thread.html
    fitzdog88's Avatar
    Apr 2012
    leeds
    59
    i felt like he was bulls**ting me a bit any was checked full bay for leaking or split hoses all ok .will my mates mac tools reader erase them or do i need a vagcom guys
    Markeyboy's Avatar
    Fan of the R-Tech!
    Aug 2011
    Thurrock, Essex
    281
    it may do, there are other tools that will do a similar job, vagcom / vcds is a very good bit of kit if you can get it tho
    1.8T SPORT AUM
    Progression Thread
    fitzdog88's Avatar
    Apr 2012
    leeds
    59
    ok thanks mate iv seen sumart on ebay a vagcom disk and lead for 20quid ish any good ?
    Markeyboy's Avatar
    Fan of the R-Tech!
    Aug 2011
    Thurrock, Essex
    281
    iv heard varied success from these, some work some dont, you cant go wrong with the origional ross-tech equipment tho
    1.8T SPORT AUM
    Progression Thread
    fitzdog88's Avatar
    Apr 2012
    leeds
    59
    ill look into it mate its off to audi tomoro for the coil pack recall see what bad news they bring lol
    fitzdog88's Avatar
    Apr 2012
    leeds
    59
    UPDATE
    just got back from audi apart from needing a cv boot thay said car is ok
    iv erased the fault codes all and this one keeps apearing
    16396 bank 1 : camshaft a (intake)
    p0012-35-10 advanced set point not reached (over-retarded) - inttermittent readiness: 0000 0001
    any ideas what this means thanks guys
    Markeyboy's Avatar
    Fan of the R-Tech!
    Aug 2011
    Thurrock, Essex
    281
    have a look here
    16396/P0012/000018 - Ross-Tech Wiki
    and here
    Fault Code 16396 Intake Camshaft Adjuster
    may be worth googling the fault codes and trawling through various sites and threads to get more info, is it still going into limp mode?
    1.8T SPORT AUM
    Progression Thread
    fitzdog88's Avatar
    Apr 2012
    leeds
    59
    im going to start looking else were now and yes mate its still going into limp mode
    fitzdog88's Avatar
    Apr 2012
    leeds
    59
    also is there any thing i could check for in the engine bay ie specific hoses , sensors wireing thanks again matt
    Aug 2010
    1,540
    youve got a problem with the vvt chain adjuster then.
    might be an oil supply problem to it or the chain is worn and stretched?
    fitzdog88's Avatar
    Apr 2012
    leeds
    59
    thanks mate how would i go about checking this and is it a expencive job if this is at fault
    fitzdog88's Avatar
    Apr 2012
    leeds
    59
    just used vagcom again and
    17938 camshaft timing adjustment p1530-35-10-short to ground- intermittent
    has come back could this be causing 16396 guys also am i right in thinking driving the car could cause major damage thanks matt
    fitzdog88's Avatar
    Apr 2012
    leeds
    59
    also iv looked on ross tech and the fault code 17938 is not there
  1. Replies: 9
    Last Post: 7th February 2012, 18:20
  2. URGENT HELP NEEDED! Fault code 16486 Air flow meter!
    By Shaun in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 5th February 2012, 19:23
  3. Replies: 2
    Last Post: 19th December 2010, 20:41
  4. Fault code help needed plz!!!
    By shaz-raul in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 31st January 2010, 17:41
  5. Replies: 5
    Last Post: 18th January 2010, 23:36
