Results 1 to 14 of 14
    Mar 2012
    Sheffield
    76
    where is the speed sensor wire please help
    I have done a quick search but could not find the answer sorry.
    I am looking to fit my sat nav and need to find the speed sensor wire the car is an S3 2001 model hopefully somebody has fitted one and can help I presume it will be ok on this to solder/scotchlock it on when i find it and it wont cause an errors on the system
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,881
    Off the top of my head, the S3 was changed to Can-Bus wiring during the facelift, so 2001 should be CanBus, I think you might need a CanBus adaptor to extract the speedpulse, otherwise, on earlier cars, it's one of the wires off the ISO connectors.
    You've got to have a laugh!
    Mar 2012
    Sheffield
    76
    Quote Originally Posted by jojo View Post
    Thankyou Jojo I will have a look hoping I don't need an adapter but no doubt I will
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Is there a way of telling if your MK1 Facelift S3 is canbus? I've not seen a definitive answer on this.
    Liam
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,881
    Quote Originally Posted by vfr800 View Post
    Liam
    I'm not 100% sure, if you scan it with VCDS, I'm sure it recognises if it's CanBus and tells you before the scan?
    vrbob's Avatar
    Jun 2007
    Southampton
    2,290
    just to add my 10p to this...
    i have a facelift S3 to which i have retro fitted RNS-E from an A4 (B6) and it supports canbus (not sure about pre-facelift though)
    In order to get the RNS-E to function correctly i had to run 3 wires from the back of the dash clocks the HU these wires were Can Hi Can Low and the Gala speed sensor wire. Cant remember off the top of my head what wires they are but if you need i can find out for you. I had to get some wire and remove the connectors on the back of the dash clocks and the splice the wires in and then fit it all back together.
    Mods : Badger 5 Stg 2 Custom Map, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
    Jun 2003
    World of my own
    9,813
    If the HU power ISO connector has both perm live and ignition on live (red with white stripe and red with yellow stripe) then it's not CANBUS, if it only has the red with white stripe perm live then it's CANBUS.
    Alex Turner
    Mar 2012
    Sheffield
    76
    Hi
    sorry for the late reply but due to days off and weather only just got round to it.
    It is a canbus system according to the information supplied by AndyMac I tried with a standard stereo before I went to the trouble of installing my system but am having doubts about it as it does not switch the stereo off when you remove key so stereo will be permantly live and you have to switch on and off (I know this will become a pain) is there a way around this?
    Also the rear amp as AndyMac advised in another post is poor and once front speakers are on you can barely here the rear ones so to be correct would need rewiring is this a lot of work?
    This leaves me with three options which is where I would like some advice please.
    1. add an ipod lead to original chorus stereo (which is best,how much & where from, what functions would I have changing track charging etc) and will I still be able to use cd changer?
    2. rewire and put my stereo in but how would I get around the auto switch off? or will I always have to switch off manually as it is a din with motorised screen will become a pain.
    3. Fit the original satnav from I think they are the later 8p models what are the differances and how much work wiring is involved aerials etc what would i need to buy and what are the differances can i use dvd tv and ipod with it ( I will search more if you think this is the best option to go down but have no idea about these units)
    Sorry for the long post but would really like to go somewhere with this and as I have only just bought the car would rather take advice from people with more experiance than myself
    cheers for reading
    Jason
    vrbob's Avatar
    Jun 2007
    Southampton
    2,290
    Check out this thread : RNS-E install
    Mar 2012
    Sheffield
    76
    Cheers that was a great help only thing is I have a single din unit although I guess that should be straightforward to change If I am honest it seems like a lot less wiring than putting my aftermarket one in.
    would you be able to send me the guide you used so I could have a look at how to do it and look at getting the parts together
    cheers
    vrbob's Avatar
    Jun 2007
    Southampton
    2,290
    Quote Originally Posted by JA50N View Post
    cheers
    Yes mate no probs just PM your email addy and i can send over the stuff i have.
    when i was buying my car i had the idea that i wanted to do the RNS-E upgrade so i found one that already had a double din hole as i knew it would make it easier. One of the pdf i will send you has the single to double din uprade info in it so that should help you out as of course i didnt do that bit.
    Mar 2012
    Sheffield
    76
    cheers you have a pm
    vrbob's Avatar
    Jun 2007
    Southampton
    2,290
    You have Email and an a PM
    Mar 2012
    Sheffield
    76
    cheers
  1. Speed signal wire?
    By GeneralWest in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th June 2011, 20:32
  2. temp sensor wire
    By tdi-man in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd August 2009, 20:02
  3. How to replace OSF wheel speed sensor wire??
    By gjrquattro in forum TT/TT-S/TT-RS Forum
    Last Post: 21st September 2008, 13:34
  4. Audi Speed sense wire
    By Mr Singh in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th December 2007, 12:19
  5. Speed Pulse wire
    By belabed in forum In-Car Entertainment
    Last Post: 22nd July 2005, 21:49
