Monster MotorsportVolks Autos
Results 1 to 9 of 9
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    How do I fit the cam belt cover?
    Hi,
    It might be a stupid question?! But I can't get the cambelt cover to fit.
    Is there a trick to doing it?
    This is as far as I can get it
    Liam
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
    Aug 2010
    1,540
    is it slotted in right at the bottom edge? part of it slots to the inside, part of it to the outside.
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Hi
    Thanks, it's not that bit that's the problem. It seems too wide to fit between the cog/wheel arch and past the engine mount.
    Liam
    Jan 2009
    West London
    269
    This cover was an absolute pain in the arse when I was doing my build. I broke one in frustration and wasted a few hours of my life trying to manipulate it in place. My engine bay isn't standard so that might have had something to do with it but I ended up loosening the engine bracket whilst holding the engine in place with a jack to make it easier to move it into place. I'm not sure if that helps you at all but it's what I ended up having to do. I never removed the cover on my engine when it was standard so I can't say if there is a particular way to do it but I can understand your pain! Just avoid snapping part of it because a replacement is about another £20!
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Cheers for that.
    Sounds like it is impossible then. I've spent an hour so far - and I wanted to smash it to bits.
    If I had a dremel I would 'alter' it a little. Hacksaw is a bit too brutal.
    Thanks, Liam
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    i fitted one on a TT recently, i found that it went on with a bit of manipulation/bending.
    get the rear edge round the pulley first, then you can wiggle the rest into place.
    TD5 Land Rover Defender build
    Aug 2010
    1,540
    it looks nearly there in the picture (as in already around the cam pulley).
    when im doing a cambelt on one of these i dont even try to take the top cover off till ive got the engine mounting side bracket unbolted. and like wise refitting it. you'll just end up loosing your temper and breaking it!
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Quote Originally Posted by murran View Post
    Nah at that point it's firmly wedged between the pulley and engine bay.
    So I need to undo the mounting bracket to fit it? I guess I might as well change the cambelt while I'm in there.
    Liam
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Cheers. I might try again but i found it was too rigid to get it round the pulley.
    Liam
  1. 2.5 V6 TDI cam belt cover
    By ms1083 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 28th June 2011, 06:40
  2. Cam adjuster Gasket, Cam Cover Paint (Pics)
    By S3 TAM in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th January 2011, 23:58
  3. Removing Cam Belt cover..........
    By s3tle in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th September 2010, 15:02
  4. cam belt, timing belt ?
    By Danny Cawsey in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th May 2010, 21:10
  5. Change alternator belt at same time as cam belt???
    By Ads in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th August 2009, 11:38
