Volks AutosEM Tuning
Results 1 to 17 of 17
Like Tree1Likes
  • 1 Post By aragorn
Thread: Compression Ratios - what does it all mean?
    Lee172's Avatar
    GT3071
    Jul 2010
    Wimbledon
    431
    My block decided to fall apart on my 1.8t so im building another. I come across a 2.0 TFSI lump for a good price so my plan is to use the TFSI crank in the 1.8T, i already have IE rods so it leaves me with pistons.. is it possible to use the TFSI pistons?
    I believe the standard size piston in the 1.8T is 81mm and the compression is around 9.3:1 (?) whereas the TFSI is 82.5mm and the compression is around 10:1. I understand that on older engines, high compression and high boost is a no no. But is the 1.8T capable of running both?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    you cant use the TFSI pistons, they're designed for a 4valve engine and would probably also stick out the top of the block.
    You need specific aftermarket pistons that are designed for 2.0 conversions on 1.8T engines.
    Something like this:
    JE 1.8T 20V Stroker Piston Set: 83MM Bore, 9.5:1 CR, 92.8MM Stroke - Pistons
    What exactly happened to your old engine? If you've blown a hole in it, what makes you think your existing rods are reusable?
    Lee172 likes this.
    TD5 Land Rover Defender build
    Lee172's Avatar
    GT3071
    Jul 2010
    Wimbledon
    431
    Thanks Aragorn, is it still possible to run higher compression alongside higher boost on a 1.8T though?
    I didnt blow a hole in the original engine, i found a lump of casting in the sump.. couldnt see where it came from so im guessing it was towards the top of the engine.. could of hydro-locked when we last put the head on - may of missed some water or something like that. I seem to have slightly low oil pressure as well so thought it could be part of an oil gallery but if it were there wouldnt be any pressure at all, and there is.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,563
    TFSI pistons are a different design to the 1.8t's...
    Std CR for 150/180 motors is 9.5:1 while 210/225 motors are 9:1
    Bigger turbo/large boost applications generally run lower compression to allow to run high boost... you need to factor the turbo capabilities too.. your current turbo for example won't produce massive amounts of boost so you can get away with higher comp pistons (I run 9.5:1's as does welly) but on the TT we built recently the GT3076r on one run held 35psi to the redline... to sustain that 'reliably' you would want to use lower comp pistons
    The pistons in the link aragorn posted is the sort of thing you want...
    <tuffty/>
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,469
    Badger is running high comp with mega high boost
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    Sparco Torino 2 sport seats, None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    "Stick a V8 in it!"
    15,370
    "high comp" or just the standard 9-9.5?
    10:1+ and high boost arent going to mix IMO.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,563
    9.5:1 JE's in Bill's car IICR... in race trim it doesn't run all the boost though....
    <tuffty/>
    RIP S3dave
    May 2004
    nr Glos
    7,167
    new engine, which is as yet unmapped, just run in, is an unknown.. its 9.25:1 CR where my previous engine was 8.5:1
    its higher CR than before.. and potentially less timing for the same boost max.. but in practical terms, max boost is pointless in it being only fwd. more spritely pickup is the aim from its new spec, and active vvt usage..
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    Lee172's Avatar
    GT3071
    Jul 2010
    Wimbledon
    431
    So what sort of CR should I go for? once I have built this bottom end, I dont intend to do it again. Me being me I will probably change to a bigger / better turbo in the future. Would I be better off going for around 9:1 CR?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,563
    If going for a stroker then 9:1 is fine and tbh no different to what you have now...
    <tuffty/>
    Nov 2011
    Finland
    131
    Hmm.. Wössner catalog gives pistons for AEB, AGN, ALT (92,8mm stroke, stroke 82.50mm, dome -10,3cm3, CR 9.2:1).
    I asked about the pistons and got answer that on my S3 I would get CR around 8.5:1.
    So what are the differences between BAM or AGU and with those I listed above?
    RIP S3dave
    May 2004
    nr Glos
    7,167
    9:1 vs 9.5:1
    www.badger5.biz
    bill@badger5.co.uk
    Nov 2011
    Finland
    131
    Are the pistons different in those engines which would make lower/higher CR?
    Or is there some differences between cylinder heads combustion chamber volumes or in other components which would affect CR?
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    a3 are slightly different to s3.
    as bill said 9.5:1 compared to 9:1
    "Stick a V8 in it!"
    15,370
    Its all in the piston, the heads are identical.
    So fitting 9.2:1 Wossners would give you 9.2:1, regardless of wether you started with an S3 or A3.
    Nov 2011
    Finland
    131
    Thanks Aragorn.. Thats exactly what I wanted to hear!
    I think that I have to find another company who dont try to fool me to get me to buy other pistons with twice price..
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,634
    Why don't you just fit the entire tfsi lump? Be a good project that
  1. Five/six-speed box ratios?
    By Magman in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 22nd September 2009, 06:36
  2. AFR Ratios
    By Broken Byzan in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd November 2008, 22:53
  3. Which Gearbox Ratios?
    By southpaw66 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th January 2007, 22:06
  4. Compression Ratios
    By Markey in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th November 2004, 09:30
  5. diff ratios
    By chrisj1260 in forum RS4 Forum (B5 and B7 Chassis)
    Last Post: 22nd March 2004, 15:52
