Monster MotorsportEM Tuning
Results 1 to 8 of 8
    Maz
    Maz's Avatar
    Moon is made of green cheese
    Jan 2005
    East
    1,008
    Coolant Leak... Help with part name/number
    Hello,
    I noticed this part was leaking a while ago and now that it's getting worse I want to replace it asap.
    Can someone help with the name/number of the part, how much it its likely to cost to replace, is it worth replacing with a genuine part and is it an easy DIY fix?
    Thanks.
    Mineral Grey [
    AMK
    beachbuggy's Avatar
    Surrey
    1,727
    Looks like the water over run pump for the turbo. Definately worth replacing, probably an expensive item new to be honest so might worth getting one of a breaking S3 imagine it would be cheap though as not exactly a desired item.
    Maz
    Maz's Avatar
    Jan 2005
    East
    1,008
    Nice one Beachbuggy, I've just found a useful thread to replace it so will give it a go once I get a replacement part.
    How to replace the after-run coolant pump - AudiWorld Forums
    Mineral Grey [
    AMK
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,056
    Its made by bosch and is fitted to a lot of cars including an omega
    Omega Vectra auxillary AUX water heater pump 2.5 * 2.6 * 3.0 * 3.2 | eBay
    not a good example but widely available...
    beachbuggy's Avatar
    Surrey
    1,727
    Quote Originally Posted by Maz View Post
    Only thing I would add to that write up is to drain the coolant first with the drain on the bottom of the radiator, do it with the cap of the expansion bottle and as the pump is pretty much the top of the system when you remove the pump you should lose next to no coolant.
    Maz
    Maz's Avatar
    Jan 2005
    East
    1,008
    Just called a local breakers yard and they have one available for £40 with a three month warranty.
    ...Audi want £125 for it.
    Mineral Grey [
    AMK
    Pushing the limits..
    Jan 2011
    Australia
    1,224
    Add Sevv on Facebook
    id buy a new one and have the piece of mind but thats just me :P
    Maz
    Maz's Avatar
    Jan 2005
    East
    1,008
    Normally so would I Sevv but on this occasion I might give a second hand part a go depending on it's condition.
    Mineral Grey [
    AMK
  1. coolant leak - can anyone explain the part?
    By boddhi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th October 2011, 20:34
  2. water leak on a metal coolant pipe (cant find the part number)
    By rozsy in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th April 2011, 20:55
  3. Part number Or Name of Coolant Hose.
    By rlc1985 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th April 2011, 10:48
  4. Help. Part number needed, coolant hose
    By Tayne in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th November 2010, 01:20
  5. Coolant leak (part number)
    By Mick a3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd July 2009, 18:15
