Monster MotorsportVolks Autos
    Feb 2012
    70
    slight fluctuation at idle, is this normal?
    When leaving the car it Idle it slightly fluctuates on the rev counter, not a lot but only very minor. I've hunted down pretty much all the breather/vacuum system and have replaced every split pipe etc which has made a noticeable difference. Will there always be a slight movement of the needle on the rev counter or should it be bang on?
    I haven't checked the hoses around the intercoolers yet as that might be my next job, which is bumper off I'm presuming.
    MrTackalakalaka's Avatar
    Jan 2012
    Truro, Cornwall
    426
    Quote Originally Posted by jackpilk View Post
    Im not the most mechanically minded but just going by experience on a few of my cars.
    Have you tried new temp sender and thermostat? I've changed mine when the idle has been at but out and it's sorted it.
    Also just a guess....timing belt? Could that have anything to do with it?
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,254
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Keeping a close eye on this thread as my needle doesn't like to settle at idle, and runs quiet high on the first start up of the day. I've had the majority of my pipes looked at and replaced very recently by a very good garage so they would have pointed something out if it needed replacing. So my next step was checking the sensors etc. I was going to start by replacing the MAF as I thought this may help?
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Try cleaning your throttle body and reset the adaptions, lumpy idle is nearly always vac related so you need to go through the pipes again, esp them under the inlet, look for greasy residues, as this is a good indicator of a split pipe...
    Its not timing belt related...
    Feb 2012
    70
    Cleaning as in removing the throttle body? That's no biggy. I've recently changed all the split hose under the inlet manni which did help things out but I'l go back and double check!
  1. Rev/Idle hunting, boost fluctuation on WOT inc fix
    By solaris in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 21st January 2013, 13:18
  2. slight vibration on idle
    By stuartyp in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 3rd January 2012, 22:44
  3. slight miss on idle
    By vw754 in forum Diesel forum
    Last Post: 7th April 2009, 00:42
  4. Rough idle and slight backfire!!
    By Lee Goodall in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st April 2008, 15:22
  5. Slight idle problem in the morning
    By nik patel in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th February 2008, 13:53
