EM TuningAH Fabrications
Thread: Exhaust bracket
    Chugger
    North Devon
    2,716
    Exhaust bracket
    Just a quick, should my car have the exhaust mount in the transmission tunnel? As it doesn't but I noticed that a pre facelift had one? My has the bolts for one but no bracket or hook on the standard exhaust?
    57 A3 2.0 TDI Sportback (140)
    Smokey_clark's Avatar
    12th Gear
    Nr Bath
    211
    I am also wondering this as i got a second hand Milltek and there is a mounting on it with nowhere to attach it to on the car.
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    I also had the same thought when I had my longlife done.
    Have four bolts holding on heat shield where the centre hanging bracket is. Maybe The exhaust just comes with it due to some model having it and some not.
    My exhaust doesn't sag or sit low so I'm guessing I just don't need one.
    MODS - Custom Code phase 1, 007p DV, various powerflex bushes, EBC grooved and drilled - red stuff pads, N249 deletion. Badger5 V2 80mm TIP. Scorpion backbox + custom centre section, LCR front splitter, Jetex Fr-08001, R32 rear ARB, Forged IE rifle drilled rods, 20mm rear & 15mm front spacers.
    TO DO - Coilovers, adjustable tie arms, DP/mani/decat, FMIC and new remap
    Chugger
    North Devon
    2,716
    I think that facelift and pre-facelift are different from what iv seen, I'm going to fit the prefacelift bracket to mine as I need more support nearer the xs power sports cat, as my exhaust removed itself yesterday on a speedbump
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    Also had mine come apart, so longlife welded centre pipe to cat issue solved.
    Chugger
    North Devon
    2,716
    That's the plan
  1. 1998 A4 1.8 non-turbo (ADR) Exhaust rear hangar/bracket question
    By au_sjo in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st December 2011, 06:18
  2. exhaust bracket
    By A3ANDYF in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th July 2010, 14:28
  3. Exhaust backbox mounting bracket bolts!
    By Westy in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th May 2010, 12:07
  4. Centre Exhaust bracket/rubbers
    By Welly in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th November 2009, 21:55
  5. Bottom exhaust bracket
    By dgannon69 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st September 2005, 18:12
