Sky InsuranceAH Fabrications
    A3tell's Avatar
    Jun 2009
    essex
    239
    Spark plug question
    Does anyone know if the ngk BKR7EIX iridium plug fit an AGU a3??
    Just want to double check b4 I buy, as I can't find a compatibility chart!
    cheers.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,350
    7 is too cold for a stock engine, you'll want 6's unless you've upgraded the turbo substantially. Probably somewhere above 250 before you'd want the 7's
    I use BKR6E's, which are copper.
    No need for fancy plugs imo, just nice standard copper ones changed often.
    TD5 Land Rover Defender build
    A3tell's Avatar
    Jun 2009
    essex
    239
    I have had mine mapped, just recently started small hasitation on accel and I know the smaller tipped iridiums give better spark!!!
    i think I put the platinum ones in last time!!
    "Stick a V8 in it!"
    15,350
    Tip size doesnt make any difference to spark strength, and if anything copper conducts electricity better!
    If your using 7's in an engine thats only remapped you may find them fouling up which will give you issues.
    i'd stick with either the BKR6E, or the standard PFR6Q plug.
  1. Spark Plug Spanner
    By Nitro in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th May 2011, 22:18
  2. spark plug help
    By gussyldr in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th December 2010, 22:02
  3. SPARK PLUG HELP
    By m444ty p in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th December 2009, 23:20
  4. spark plug question
    By jazzyc in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st July 2007, 21:48
  5. no spark on 3rd plug
    By a3stu in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th August 2006, 18:24
