Chris NottSky Insurance
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By s3dave
Thread: S3 Engine clean-up and TIP help :) APY
    actualeddie's Avatar
    Feb 2012
    Waltham Abbey, Essex
    211
    Hey everyone
    Recently bought an S3, got a bit done on it really. Took it for test drive fine, drove it back from Oxford to Essex fine next day Overheated! Long story short had to change the cylinder head which was actually cracked (I hear a cracked head on this engine is rare)
    The cars had a few things done to it before me, carbon airbox, Forge DV, remap (AMD to 267hp apparently) and now I want to tune her.
    First of all under the engine cover is really messy and want to clean that up. Would a N249 bypass help?
    That, vacuum box is just loose... very annoying!
    If I throw a few more pics up, could someone direct me in the right direction for the correct Silicone TIP?
    I could just take it to a garage and have them fit it, but what fun is that? I'm DIY and love to learn.
    Cheers guys, sorry if all this has come up before.
    Eddie
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    A b5 tip is what you will want for best results....
    S3/TT/LCR-K04 Full Induction Kit Package
    gsmboy likes this.
    Feb 2012
    211
    Cheers, does that mean get rid of the air filter i already have? Can you actually go anywhere and buy these parts or is it all by order?
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    You can drive to bills place in Gloucester. Or just ring him and order it. Believe they are on back order at the mo?
    And yeah get the bypass done. Some cable ties to tidy up loose pipes should see you on the way to a tidy bay
    MODS - Custom Code phase 1, 007p DV, various powerflex bushes, EBC grooved and drilled - red stuff pads, N249 deletion. Badger5 V2 80mm TIP. Scorpion backbox + custom centre section, LCR front splitter, Jetex Fr-08001, R32 rear ARB, Forged IE rifle drilled rods, 20mm rear & 15mm front spacers.
    TO DO - Coilovers, adjustable tie arms, DP/mani/decat, FMIC and new remap
    Feb 2012
    211
    Bit of a drive for me lol. Ill order it Think ill give the bypass a try tomorrow and like you said cable tie it up. Maybe OCD since it gets covered, but I know its like that lol. Just had to buy a replacement silicone hose, the orange/red one at the back of the engine; £65 not to bad.
    Cheers for advice guys
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    717
    B5 TIP and get a proper DV to replace that Splitter valve, the Forge 007P is the one most recommend, the splitter valve will cause problems as the MAF wont see the airflow it expects.
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
    Feb 2012
    211
    Ah k, It was on there when I purchased the car, why would this have been chosen over the 007p? This is about £50 more than the 007p so could sell it???
  1. Is there a straight swap silicone TIP for the APY engine?
    By Benjiman46 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th March 2012, 12:44
  2. Which TIP for 2000 APY?
    By coyle in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd January 2011, 10:12
  3. Apy tip fitting
    By future in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st October 2010, 11:45
  4. Fitting a tip to an apy engine
    Last Post: 9th July 2010, 20:42
  5. Silicone TIP for an APY engine....
    By warleydaddy in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th March 2009, 19:15
