Volks AutosEM Tuning
    Sep 2011
    doncaster
    98
    Unhappy Slight power loss
    Recently had head change on my s3 to an agu head, haven't managed to get transition gasket yet so just put agu intake gasket on. Could this affect my car and cause slight power loss? Any thought appreciated thanks
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Have you tried resetting the adaptions, as the hardware has changed....?
    Sep 2011
    doncaster
    98
    yes mate reset adaptions, just seems to be holding back after 4000. seems a bit hesistant.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    If you have checked the usual, pipework etc, i would get it logged to see whats going on...
    Sep 2011
    doncaster
    98
    will do, il post it up here tomor
    Sep 2011
    doncaster
    98
    just been to speak with my friend, audi/vw specialist and he says it could be the head i recently had put on, agu code. i havent managed to get transition gasket for it yet and only put agu gasket on. could this cause the power loss with the turbulence? this is the fault code im gettin.
    16684 random/multiple cylinder misfire
    p0300 - 35-10 ---intermittent
    he also said loggin would be pointless as it may just be incorrect AFR. any thoughts on this?
    the misfires only seem to occur after 4000 rpm
    another noticible thing is that it only misfired on cylinder 1 and 3 while on the computer, none on other two cylinders
  1. Help / Advice needed, A3 1.8T, Power blipping /slight loss of power
    By Lex007 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th August 2009, 09:49
  2. tdi130 slight mpg, power problem
    By fifer1981 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th February 2009, 13:49
  3. slight loss in power....
    By J45SON in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th January 2008, 14:22
  4. slight power delay on2.tdi DSG
    By celica in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th February 2005, 14:58
  5. slight power delay on2.tdi DSG
    Last Post: 12th February 2005, 16:05
