Volks AutosEM Tuning
    Golf with BAM Engine
    Jan 2011
    54
    Whilst changing over to catch tank - replacing breather hoses, sizes?
    Whilst doing the Catch Tank set up for all the known positives I have also thought about replacing some of the hoses in the engine bay for new items. In the picture below the hose coloured blue is from the end of the inlet manifold to the brake servo with a one way inline valve. What internal diameter is this, 12 or 13mm?
    In the diagram there is also the hose in red from the throttle body down to the TIP, as my car has a BAM engine transplant, I don't have the left portion to the charcoal canister (will be removing this, but retaining the wiring and valve to avoid issues), what internal diameter is this right part of the red hose, I believe looking at the bottom image it is 8mm?
    Other thing that seems odd is there are 2 inline one way valves in the red hose from the throttle body to the TIP, all seems standard but does there need to be 2?
    G60DAN's Avatar
    Cornwall
    321
    Sorry cant help with the pipes but what did you clean your in let wit.
    Jan 2011
    54
    Sorry, these are pictures I've found online whilst undertaking my catch tank install research.
    G60DAN's Avatar
    Cornwall
    321
    Thanks anyway
  1. Bam breather hoses
    By Eddie S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st April 2012, 22:29
  2. Breather Hoses
    By tonybolony in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th March 2012, 22:52
  3. 1.8t breather hoses
    By orion1210 in forum General Technical / How To
    Last Post: 14th February 2010, 14:19
  4. Breather and vacum hose sizes,help neeeded
    By afcjay in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th October 2008, 00:02
