Monster MotorsportChris Nott
Results 1 to 28 of 28
    Apr 2011
    Dublin, Ireland
    619
    Anyone had problems with XS/Relentless Manifold?
    There are alot of these out there now. What problems have people had so far if any.
    B5 v1 Tip, B5 Exhaust Manifold, Beach Buggy Hybrid, Pipewerx D.P and cat bypass, Miltek resonated cat back, AH Fabs v2 Intercooler, S2000 Filter, 83mm 9.5:1 CP Pistons, Brute Rods, Bosch 550cc Injectors, Oil Catch can, N249 delete, B5 Phenolic Gasket, Devils Own Water Meth Kit, Forge baffled sump.
    H&R Springs, Koni FSD Shocks, s3dave's rear tie bars, R32 ARB's, LCR Brembo's, 18" ttrs alloys, replaced all suspension bushes, 15/20mm spacers front/rear, Vibratechnics Engine Mounts.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    I think there is only one fail on the welds reported so far, (prawns) but that maybe an unfair claim as he has used it on the track..
    If this should withstand this is another question....
    Welly is not noted to be light footed, and it seemed ok for him the few days he had it on..
    Jimgrim77's Avatar
    Nov 2011
    Clevedon, Near Bristol
    957
    +1 on that.
    They are awesome.
    Only comment is that they run very hot in a very very confined space.
    When adapting the heat shields at install just ensure that it remains adequate to protect pipe work.
    Can be fiddily to avoid annoying rattle. Took a bit of playing around.
    Ming Blue S3, Stage 3 Hybrid Turbo, Custom Map, Bosch 480 injectors, Custom TIP, Forge FMIC, 3" Downpipe, 200 Cell Sport CAT, Full Stainless, XS Power Mani, 6 Paddle Clutch, Red silicone hoses, LCR Brembo's, Forge 007p, KW Suspension Kit, Green filter, THS Mounts, 11mm & 16mm spacers, H&R Anti-roll bars, RS6 18" alloys, Michelin PS3's, Red Dog Bone Mount, Neuspeed quickshift, Boost Gauge, Aero wipers, LCR splitter, Forge Tie-bars, LED bulbs, Armrest, Custom TT pedals.
    Reesy's Avatar
    East Sussex
    3,604
    I know that Westy has one of these ready to go on his car, and he has had the welds beefed up to try and stop any future cracks appearing, I'm also pretty sure that prawns replacement Mani is going straight to the same place. I think it might be a necessary precaution after seeing the damage to prawns
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,360
    Dave: your thread title is missleading, and implies you have a problem.
    it's a bit like me putting:
    *JENSEN BUTTON DEAD*
    ...at some point in the distant future (see what I mean?)
    Anyway, back on topic, To my knowledge mine is the only one to break thats been made to fit and work properly in the first place, but mine is a modified V1 manifold and not the current V2 batch.
    Little difference in the way it's built, so only time will tell. Mine's being beefed up by Dave at Stainless Engineering too like Westys
    Jimgrim77's Avatar
    Nov 2011
    957
    Agreed. I panicked a little too.
    ShaunS3's Avatar
    Yorkshire & Humber Rep.
    Mar 2012
    West Yorkshire
    882
    What are the release dates for V1 and V2?
    Feb 2012
    95
    Is it the same as the relentless one? My friends one cracked last week with less then 1000miles on his gt2871r build, he is now going custom manifold
    beachbuggy's Avatar
    Surrey
    1,744
    I have to say mines coming off next week as ive developed a blow. I took the head off the other week as thought it was the manifold to turbo gasket or dp to turbo so replaced both but it's still there. Engines coming out on Wednesday to sort the clutch and also to find the exhaust blow, I'm hoping it's a gasket but a little bit worried its the manifold as the manifold is the only thing left to check. Chances are though it's just a gasket blowing.
    Only other issue I've had is getting the hidden nut on the turbo stud, what a f****ing pain the arse....
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,273
    Quote Originally Posted by Vagworld View Post
    Quote Originally Posted by beachbuggy View Post
    Guys, can you both get photos of your mani's when they come off please so we can see where the cracks (if they have cracked) are.
    Here's a few pics of mine after s3dave reinforced the welds:
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Yes it is, can you get hold of it? As westy says, it will help people if you can take a pic of the crack to see if it is failing in the same places..
    beachbuggy's Avatar
    Surrey
    1,744
    No probs, I know mine hasn't cackled like prawns as I can clearly see there's nothing wrong with it in the same place. I think mine is a gasket issue but will be removing it anyway to ensure no leaks.
    Jimgrim77's Avatar
    Nov 2011
    957
    Thats interesting.
    I have to say that mine also seemed fine when I had mine apart last/this week.
    The version 2 has lots of extra welds and my exhaust guy was very satisfied with it and felt strengthening work, whilst possible, seemed unnecessary. However, each mani despite being very similar will not be identical.
    Will be running more tests this Tuesday on the dyno once it's off the ramps and pieced back together with new top mounts and that will provide a clearer indication of where it's at.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,558
    Changed title to make it more relevant...
    <tuffty/>
    Westy's Avatar
    Dec 2008
    17,273
    I'm also still waiting on some pics from those of you that have made heat shields to protect the turbo outlet hose.
    S3 Build Thread
    Apr 2011
    Dublin, Ireland
    619
    Thanks Tufty for the title change, had a couple of beers before posting. So recommendations so far are to get the welds beefed up. Like Westy I would also like to see what people have done heat shield wise.
    liquids3's Avatar
    Jul 2010
    Bristol
    933
    Quote Originally Posted by Westy View Post
    Mine will be ready in around a week,just received my injectors,nearly there lol
    Audi S3- 1.8T Quattro
    Liquid Yellow
    Audi R8 Rims
    Its never finished!
    Westy's Avatar
    Dec 2008
    17,273
    Quote Originally Posted by liquids3 View Post
    Not good for me mate, I'm fitting mine next Saturday
    S3 Build Thread
    liquids3's Avatar
    Jul 2010
    Bristol
    933
    If you do decide to fit a heat sheild,you'll want to mount it after mani is on anyway,so wnt be a problem,so do you have everything ready,injectors fmic dp?
    Liquid Yellow
    Audi R8 Rims
    Its never finished!
    v5 tt's Avatar
    Aug 2011
    Southampton
    85
    This wasnt on a TT by any chance ? i saw a TT for sale with a GT28 eliminator with xs/relentless manifold
    XFi
    Jun 2010
    344
    Getting mine fitted on Monday and picking it up on Wednesday, cant wait! Hope I don't get any problems.
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,098
    Quote Originally Posted by v5 tt View Post
    Curious on how these eliminators perform after being mated with a high flow Mani as it is a possibility with a close friends car as contemplating this or a hybrid k04?
    Power & Torque 335bhp 285ftlb
    0-60 4.64 1/4 mile 13.02
    My GTX3071r Build Thread
    http://www.audi-sport.net/vb/a3-s3-f...ld-thread.html
    Chlippo's Avatar
    Apr 2010
    Canada/USA/Lebanon
    666
    Didnt have any problems on mine so far. My car is stock.
    I beleive those are not designed to run anything other than a K04 or K04 hybrid. A GT turbo would probably need a higher quality manifold.
    As said above, only fitting was the hard part. Im happy with the rest
    Also note that for the price we are paying...im even more than happy with the product
    Audi S3 AMK
    Relentless-Manifold, Relentless-3" downpipe decat, Forge 007 DV, autobahn88 TIP, K&N Panel filter, EBC yellowstuff brake pads, R32 ARB, Custom column dual gauge pod...waiting for a remap!
    For help/info/pricing on xs manifold and downpipe pm me (not affiliated, nor a reseller trader, just an enthusiast!)
    Feb 2012
    95
    yes it was, i think he is going to keep it now, he was talking about custom manifolds last night and converting the turbo to t3 flange
    RIP S3dave
    May 2004
    nr Glos
    7,162
    i have had several people call me asking about things re manifolds for k04 and of those who ran xs/relentless, all of them were on their 2nd or more after theirs cracked. These were V1's
    V2 weld quality looks no different, and consistency between them is always "inconsistent" anyhows. Pot Luck plays a factor.
    Relentless have been told by Samy re the cracks and say they are going to do something different and send him a sample. They have been told by sammy from me to backpurge the welds.
    We will see.
    who knows..
    Lottery anyone?
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Westy's Avatar
    Dec 2008
    17,273
    We will see.
    who knows..
    Lottery anyone?
    I'm hoping my beefed up welds will last a bit longer then.
    S3 Build Thread
  28. #27
    Apr 2011
    Dublin, Ireland
    619
    So any further pics of cracked manifolds. Where on the mani are they cracking. @Westy. Did you get all the welds gone over. Any pics of heatshields etc.
  29. #28
    Westy's Avatar
    Dec 2008
    17,273
    Quote Originally Posted by IrishDave View Post
    I'm yet to make a heat shield. The only issues I had at the weekend was the way the mani and the DP fit around each other, or dont in this situation! The DP flange around the top bolt hole wouldn't clear the 4th runner of the mani and I had to grind away some of the material to make it fit flush. Once it was in I then had the problem of not being able to fit a bolt into the hole as the bolt head would foul the 4th runner on the mani too!
    Here was the clearance:
    S3 Build Thread
  1. S3 Noise on Relentless Downpipe/Sport cat
    By sideways steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st October 2012, 00:23
  2. Relentless K04 Manifolds
    By Yohan87 in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd March 2012, 18:48
  3. Replies: 16
    Last Post: 14th March 2012, 10:24
  4. People with the relentless down pipe and sport cat
    By Andrew@A.L.D in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd September 2010, 22:23
  5. Exhaust Manifold Problems S3
    By ash_s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th November 2006, 19:32
